Datasheet LTC1603 (Analog Devices) - 6
DescriptionHigh Speed, 16-Bit, 250ksps Sampling A/D Converter with Shutdown
Pages / Page20 / 6 — PIN FUNCTIONS. A +. IN (Pin 1):. OGND (Pin 28):. DD (Pin 29):. A –. IN …
File Format / SizePDF / 261 Kb
PIN FUNCTIONS. A +. IN (Pin 1):. OGND (Pin 28):. DD (Pin 29):. A –. IN (Pin 2):. RD (Pin 30):. VREF (Pin 3):. CONVST (Pin 31):
PIN FUNCTIONS A + IN (Pin 1): OGND (Pin 28): DD (Pin 29): A – IN (Pin 2): RD (Pin 30): VREF (Pin 3): CONVST (Pin 31):
LTC1603
U U U PIN FUNCTIONS A + IN (Pin 1):
Positive Analog Input. The ADC converts the
OGND (Pin 28):
Digital Ground for Output Drivers. difference voltage between A + – IN and AIN with a differen-
OV
tial range of ±2.5V. A +
DD (Pin 29):
Digital Power Supply for Output Drivers. IN has a ±2.5V input range when Bypass to OGND with 10µF tantalum in parallel with 0.1µF A – IN is grounded. ceramic.
A – IN (Pin 2):
Negative Analog Input. Can be grounded, tied
RD (Pin 30):
Read Input. A logic low enables the output to a DC voltage or driven differentially with A + IN . drivers when CS is low.
VREF (Pin 3):
2.5V Reference Output. Bypass to AGND with
CONVST (Pin 31):
Conversion Start Signal. This active 2.2µF tantalum in parallel with 0.1µF ceramic. low signal starts a conversion on its falling edge when CS
REFCOMP (Pin 4):
4.375V Reference Compensation Pin. is low. Bypass to AGND with 47µF tantalum in parallel with 0.1µF
CS (Pin 32):
The Chip Select Input. Must be low for the ceramic. ADC to recognize CONVST and RD inputs.
AGND (Pins 5 to 8):
Analog Grounds. Tie to analog ground
SHDN (Pin 33):
Power Shutdown. Drive this pin low with plane. CS low for nap mode. Drive this pin low with CS high for
DVDD (Pin 9):
5V Digital Power Supply. Bypass to DGND sleep mode. with 10µF tantalum in parallel with 0.1µF ceramic.
VSS (Pin 34):
– 5V Negative Supply. Bypass to AGND with
DGND (Pin 10):
Digital Ground for Internal Logic. Tie to 10µF tantalum in parallel with 0.1µF ceramic. analog ground plane.
AVDD (Pin 35):
5V Analog Power Supply. Bypass to AGND
D15 to D0 (Pins 11 to 26):
Three-State Data Outputs. D15 with 10µF tantalum in parallel with 0.1µF ceramic. is the Most Significant Bit.
AVDD (Pin 36):
BUSY (Pin 27):
The BUSY output shows the converter with 10µF tantalum in parallel with 0.1µF ceramic and status. It is low when a conversion is in progress. Data is connect this pin to Pin 35 with a 10Ω resistor. valid on the rising edge of BUSY. 1603f 6
