LTC2209 power requireMents The l denotes the specifications which apply over the full operating temperaturerange, otherwise specifications are at TA = 25°C. AIN = –1dBFS. (Note 4)SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITS VDD Analog Supply Voltage (Note 8) l 3.135 3.3 3.465 V PSHDN Shutdown Power SHDN = VDD 0.2 mW STANDARD LVDS OUTPUT MODE OVDD Output Supply Voltage (Note 8) l 3 3.3 3.6 V IVDD Analog Supply Current l 467 510 mA IOVDD Output Supply Current l 74 90 mA PDIS Power Dissipation l 1785 1980 mW LOW POWER LVDS OUTPUT MODE OVDD Output Supply Voltage (Note 8) l 3 3.3 3.6 V IVDD Analog Supply Current l 467 510 mA IOVDD Output Supply Current l 41.6 50 mA PDIS Power Dissipation l 1678 1848 mW CMOS OUTPUT MODE OVDD Output Supply Voltage (Note 8) l 0.5 3.6 V IVDD Analog Supply Current l 464 507 mA PDIS Power Dissipation l 1531 1673 mW tiMing characteristics The l denotes the specifications which apply over the full operating temperaturerange, otherwise specifications are at TA = 25°C. (Note 4) SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITS fS Sampling Frequency (Note 8) l 1 160 MHz tL ENC Low Time Duty Cycle Stabilizer Off (Note 7) l 2.97 3.125 1000 ns Duty Cycle Stabilizer On (Note 7) l 2.1 3.125 1000 ns tH ENC High Time Duty Cycle Stabilizer Off (Note 7) l 2.97 3.125 1000 ns Duty Cycle Stabilizer On (Note 7) l 2.1 3.125 1000 ns tAP Sample-and-Hold Aperture Delay 1 ns LVDS OUTPUT MODE (STANDARD and LOW POWER) tD ENC to DATA Delay (Note 7) l 1.3 2.5 3.8 ns tC ENC to CLKOUT Delay (Note 7) l 1.3 2.5 3.8 ns tSKEW DATA to CLKOUT Skew (tC-tD) (Note 7) l –0.6 0 0.6 ns tRISE Output Rise Time 0.5 ns tFALL Output Fall Time 0.5 ns Data Latency Data Latency 7 Cycles CMOS OUTPUT MODE tD ENC to DATA Delay (Note 7) l 1.3 2.7 4.0 ns tC ENC to CLKOUT Delay (Note 7) l 1.3 2.7 4.0 ns tSKEW DATA to CLKOUT Skew (tC-tD) (Note 7) l –0.6 0 0.6 ns Data Latency Data Latency Full Rate CMOS 7 Cycles Demuxed 7 Cycles 2209fb 6 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Converter Characteristics Analog Input Dynamic Accuracy Common Mode Bias Characteristics Digital Inputs and Digital Outputs Power Requirements Timing Characteristics Electrical Characteristics Timing Diagram Typical Performance Characteristics Pin Functions Block Diagram Definitions Applications Information Package Description Revision History Related Parts
