Datasheet LTC2289 (Analog Devices) - 2
Description | Dual 10-Bit, 80Msps Low Noise 3V ADC |
Pages / Page | 24 / 2 — ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. OVDD = VDD (Notes 1, … |
File Format / Size | PDF / 677 Kb |
ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. OVDD = VDD (Notes 1, 2). Order Options. CO VERTER CHARACTERISTICS The
LTC2289
W W W U U W U ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO OVDD = VDD (Notes 1, 2)
Supply Voltage (V TOP VIEW DD) ... 4V Digital Output Ground Voltage (OGND) ... –0.3V to 1V DD DD Analog Input Voltage (Note 3) ... –0.3V to (V 64 GND 63 V 62 SENSEA 61 VCMA 60 MODE 59 SHDNA 58 OEA 57 OFA 56 DA9 55 DA8 54 DA7 53 DA6 52 DA5 51 DA4 50 OGND 49 OV DD + 0.3V) Digital Input Voltage .. –0.3V to (V + DD + 0.3V) AINA 1 48 DA3 A – INA 2 47 DA2 Digital Output Voltage .. –0.3V to (OVDD + 0.3V) REFHA 3 46 DA1 REFHA 4 45 DA0 Power Dissipation .. 1500mW REFLA 5 44 NC REFLA 6 43 NC Operating Temperature Range VDD 7 42 NC CLKA 41 NC LTC2289C ... 0°C to 70°C 8 65 CLKB 9 40 OFB LTC2289I ...–40°C to 85°C VDD 10 39 DB9 REFLB 11 38 DB8 Storage Temperature Range ..–65°C to 125°C REFLB 12 37 DB7 REFHB 13 36 DB6 REFHB 14 35 DB5 A – INB 15 34 DB4 A + INB 16 33 DB3 17 18 19 20 32 DD NC 24 NC 25 NC 26 NC 27 DD GND V OEB 23 DB0 28 DB1 29 DB2 30 VCMB MUX 21 OGND 31 OV SENSEB SHDNB 22 UP PACKAGE 64-LEAD (9mm × 9mm) PLASTIC QFN TJMAX = 125°C, θJA = 20°C/W EXPOSED PAD (PIN 65) IS GND AND MUST BE SOLDERED TO PCB ORDER PART QFN PART* NUMBER MARKING LTC2289CUP LTC2289UP LTC2289IUP
Order Options
Tape and Reel: Add #TR Lead Free: Add #PBF Lead Free Tape and Reel: Add #TRPBF Lead Free Part Marking: http://www.linear.com/leadfree/ Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container.
U CO VERTER CHARACTERISTICS The
C. (Note 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
Resolution ● 10 Bits (No Missing Codes) Integral Linearity Error Differential Analog Input (Note 5) ● –0.6 ±0.1 0.6 LSB Differential Differential Analog Input ● –0.5 ±0.1 0.5 LSB Linearity Error Offset Error (Note 6) ● –12 ±2 12 mV Gain Error External Reference ● –2.5 ±0.5 2.5 %FS Offset Drift ±10 µV/°C Full-Scale Drift Internal Reference ±30 ppm/°C External Reference ±5 ppm/°C Gain Matching External Reference ±0.3 %FS Offset Matching ±2 mV Transition Noise SENSE = 1V 0.08 LSBRMS 2289fa 2
