Datasheet LTC2380-24 (Analog Devices) - 4
Description24-Bit, 1.5Msps/2Msps, Low Power SAR ADC with Integrated Digital Filter
Pages / Page32 / 4 — DYNAMIC. ACCURACY The. denotes the specifications which apply over the …
DYNAMIC. ACCURACY The. denotes the specifications which apply over the full operating temperature range,
DYNAMIC ACCURACY The denotes the specifications which apply over the full operating temperature range,
LTC2380-24
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C and AIN = –1dBFS. (Notes 4, 9) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SFDR Spurious Free Dynamic Range fIN = 2kHz, VREF = 5V l 114 120 dB –3dB Input Linear Bandwidth 34 MHz Aperture Delay 500 ps Aperture Jitter 4 psRMS Transient Response Full–Scale Step 95 ns
REFERENCE INPUT The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VREF Reference Voltage (Note 5) l 2.5 5.1 V IREF Reference Input Current (Note 10) l 1.9 2.1 mA VIHDGC High Level Input Voltage REF/DGC Pin l 0.8VREF V VILDGC Low Level Input Voltage REF/DGC Pin l 0.2VREF V
DIGITAL INPUTS AND DIGITAL OUTPUTS The
l
VIH High Level Input Voltage l 0.8 • OVDD V VIL Low Level Input Voltage l 0.2 • OVDD V IIN Digital Input Current VIN = 0V to OVDD l –10 10 μA CIN Digital Input Capacitance 5 pF VOH High Level Output Voltage IO = –500µA l OVDD – 0.2 V VOL Low Level Output Voltage IO = 500µA l 0.2 V IOZ Hi-Z Output Leakage Current VOUT = 0V to OVDD l –10 10 µA ISOURCE Output Source Current VOUT = 0V –10 mA ISINK Output Sink Current VOUT = OVDD 10 mA
POWER REQUIREMENTS The
l
VDD Supply Voltage l 2.375 2.5 2.625 V OVDD Supply Voltage l 1.71 5.25 V IVDD Supply Current N = 4, fSMPL = 2Msps l 11.2 13 mA IOVDD Supply Current N = 4, fSMPL = 2Msps (CL = 20pF) 0.4 mA IPD Power Down Mode Conversion Done (IVDD + IOVDD + IREF) l 1 90 μA PD Power Dissipation N = 4, fSMPL = 2Msps 28 32.5 mW Power Down Mode Conversion Done (IVDD + IOVDD + IREF) 2.5 225 μW
ADC TIMING CHARACTERISTICS The
l
fSMPL Maximum Sampling Frequency N ≥ 4 l 2 Msps fODR Output Data Rate l 1.5 Msps 238024fa 4 For more information www.linear.com/LTC2380-24 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Converter Characteristics Dynamic Accuracy Reference Input Digital Inputs and Digital Outputs Power Requirements ADC Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Timing Diagram Applications Information Package Description Revision History Typical Application Related Parts
