Datasheet LTC2380-24 (Analog Devices) - 5
Description24-Bit, 1.5Msps/2Msps, Low Power SAR ADC with Integrated Digital Filter
Pages / Page32 / 5 — ADC. TIMING CHARACTERISTICSThe. denotes the specifications which apply …
ADC. TIMING CHARACTERISTICSThe. denotes the specifications which apply over the full operating
ADC TIMING CHARACTERISTICSThe denotes the specifications which apply over the full operating
LTC2380-24
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
tCONV Conversion Time l 343 392 ns tACQ Acquisition Time tACQ = tCYC – tCONV – tBUSYLH (Note 7) l 95 ns tCYC Time Between Conversions l 500 ns tCNVH CNV High Time l 20 ns tCNVL Minimum Low Time for CNV (Note 11) l 20 ns tBUSYLH CNV↑ to BUSY↑ Delay CL = 20pF l 13 ns tQUIET SCK Quiet Time from CNV↑ (Note 7) l 10 ns tSCK SCK Period (Notes 11, 12) l 10 ns tSCKH SCK High Time l 4 ns tSCKL SCK Low Time l 4 ns tSSDISCK SDI Setup Time From SCK↑ (Note 11) l 4 ns tHSDISCK SDI Hold Time From SCK↑ (Note 11) l 1 ns tSCKCH SCK Period in Chain Mode tSCKCH = tSSDISCK + tDSDO (Note 11) l 13.5 ns tDSDO SDO Data Valid Delay from SCK↑ CL = 20pF, OVDD = 5.25V l 7.5 ns CL = 20pF, OVDD = 2.5V l 8 ns CL = 20pF, OVDD = 1.71V l 9.5 ns tHSDO SDO Data Remains Valid Delay from SCK↑ CL = 20pF (Note 7) l 1 ns tDSDOBUSYL SDO Data Valid Delay from BUSY↓ CL = 20pF (Note 7) l 5 ns tEN Bus Enable Time After RDL↓ (Note 11) l 16 ns tDIS Bus Relinquish Time After RDL↑ (Note 11) l 13 ns
Note 1:
Note 7:
Guaranteed by design, not subject to test. may cause permanent damage to the device. Exposure to any Absolute
Note 8:
Bipolar zero-scale error is the offset voltage measured from –0.5LSB Maximum Rating condition for extended periods may affect device when the output code flickers between 0000 0000 0000 0000 0000 0000 reliability and lifetime. and 1111 1111 1111 1111 1111 1111. Full-scale bipolar error is the
Note 2:
All voltage values are with respect to ground. worst-case of –FS or +FS untrimmed deviation from ideal first and last code
Note 3:
When these pin voltages are taken below ground or above REF or transitions and includes the effect of offset error. OVDD, they will be clamped by internal diodes. This product can handle
Note 9:
All specifications in dB are referred to a full-scale ±5V input with a input currents up to 100mA below ground or above REF or OVDD without 5V reference voltage. latchup.
Note 10:
fSMPL = 2MHz, IREF varies proportionally with sample rate.
Note 4:
VDD = 2.5V, OVDD = 2.5V, REF = 5V, VCM = 2.5V, fSMPL = 1.5MHz,
Note 11:
Parameter tested and guaranteed at OVDD = 1.71V, OVDD = 2.5V REF/DGC = VREF, N = 1. and OVDD = 5.25V.
Note 5:
Recommended operating conditions.
Note 12:
tSCK of 10ns maximum allows a shift clock frequency up to
Note 6:
Integral nonlinearity is defined as the deviation of a code from a 100MHz for rising edge capture. straight line passing through the actual endpoints of the transfer curve. The deviation is measured from the center of the quantization band. 0.8 • OVDD tWIDTH 0.2 • OVDD t tDELAY 50% 50% DELAY 238024 F01 0.8 • OVDD 0.8 • OVDD 0.2 • OVDD 0.2 • OVDD
Figure 1. Voltage Levels for Timing Specifications
238024fa For more information www.linear.com/LTC2380-24 5 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Converter Characteristics Dynamic Accuracy Reference Input Digital Inputs and Digital Outputs Power Requirements ADC Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Timing Diagram Applications Information Package Description Revision History Typical Application Related Parts
