Datasheet LT3013 (Analog Devices) - 2
Description250mA, 4V to 80V Low Dropout Micropower Linear Regulator with PWRGD
Pages / Page20 / 2 — ABSOLUTE MAXIMUM RATINGS. (Note 1). PIN CONFIGURATION. ORDER INFORMATION. …
File Format / SizePDF / 233 Kb
ABSOLUTE MAXIMUM RATINGS. (Note 1). PIN CONFIGURATION. ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LT3013
Storage Temperature Range IN Pin Voltage ...±80V TSSOP Package ...–65°C to 150°C OUT Pin Voltage ..±60V DFN Package ..–65°C to 125°C IN to OUT Differential Voltage ...±80V Operating Junction Temperature Range ADJ Pin Voltage ... ±7V (Notes 3, 10, 11) SHDN Pin Input Voltage ..±80V LT3013E ...–40°C to 125°C CT Pin Voltage ...7V, –0.5V LT3013HFE ...–40°C to 140°C PWRGD Pin Voltage ...80V, –0.5V LT3013MP..–55°C to 125°C Output Short-Circuit Duration .. Indefi nite Lead Temperature (FE16 Soldering, 10 sec) ... 300°C
PIN CONFIGURATION
TOP VIEW TOP VIEW GND 1 16 GND NC 1 12 NC NC 2 15 NC OUT 2 11 IN OUT 3 14 IN OUT 3 10 IN OUT 4 13 IN 13 17 ADJ 4 9 NC ADJ 5 12 NC SHDN GND 5 8 SHDN GND 6 11 PWRGD 7 PWRGD 6 7 C 10 CT T GND 8 9 GND DE PACKAGE 12-LEAD (4mm s 3mm) PLASTIC DFN FE PACKAGE 16-LEAD PLASTIC TSSOP TJMAX = 125°C, θJA = 40°C/W, θJC = 16°C/W EXPOSED PAD (PIN 13) IS GND TJMAX = 140°C, θJA = 40°C/W, θJC = 16°C/W MUST BE SOLDERED TO PCB EXPOSED PAD (PIN 17) IS GND MUST BE SOLDERED TO PCB
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3013EDE#PBF LT3013EDE#TRPBF 3013 12-Lead (4mm x 3mm) Plastic DFN –40°C to 125°C LT3013EFE#PBF LT3013EFE#TRPBF 3013EFE 16-Lead Plastic TSSOP –40°C to 125°C LT3013HFE#PBF LT3013HFE#TRPBF 3013HFE 16-Lead Plastic TSSOP –40°C to 140°C LT3013MPFE#PBF LT3013MPFE#TRPBF 3013MPFE 16-Lead Plastic TSSOP –55°C to 125°C
LEAD BASED FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3013EDE LT3013EDE#TR 3013 12-Lead (4mm x 3mm) Plastic DFN –40°C to 125°C LT3013EFE LT3013EFE#TR 3013EFE 16-Lead Plastic TSSOP –40°C to 125°C LT3013HFE LT3013HFE#TR 3013HFE 16-Lead Plastic TSSOP –40°C to 140°C LT3013MPFE LT3013MPFE#TR 3013MPFE 16-Lead Plastic TSSOP –55°C to 125°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/ 3013fe 2
