Datasheet LT3063 (Analog Devices) - 5
Description45V VIN, Micropower, Low Noise, 200mA LDO with Active Output Discharge
Pages / Page22 / 5 — TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. …
File Format / SizePDF / 975 Kb
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Typical Dropout Voltage. Guaranteed Dropout Voltage
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted Typical Dropout Voltage Guaranteed Dropout Voltage
LT3063 Series
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Typical Dropout Voltage Guaranteed Dropout Voltage Dropout Voltage
550 550 550 = TEST POINTS 500 500 T 500 J = 150°C 450 T I J = 150°C 450 450 L = 200mA 400 400 400 I 350 L = 100mA TJ = 125°C 350 TJ = 25°C 350 TAGE (mV) 300 TAGE (mV) 300 TAGE (mV) 300 250 T 250 250 J = 25°C IL = 50mA 200 200 200 DROPOUT VOL 150 DROPOUT VOL 150 DROPOUT VOL 150 IL = 10mA 100 100 100 50 50 50 0 0 0 0 25 50 75 100 125 150 175 200 0 25 50 75 100 125 150 175 200 –75 –50 –25 0 25 50 75 100 125 150 175 OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) TEMPERATURE (°C) 3063 G01 3063 G02 3063 G03
Quiescent Current LT3063-3.3 Output V LT3063–3.3 Output V oltage oltage LT3063-5 Output V L oltage T3063–5 Output Voltage
80 3.366 V 5.100 IN = VSHDN = 6V I 3.355 L = 1mA I 70 VOUT = 5V L = 1mA 5.080 IL = 5µA 3.344 5.060 60 3.333 3.322 5.040 50 3.311 TAGE (V) 5.020 TAGE (V) 40 3.300 5.000 3.289 30 4.980 3.278 OUTPUT VOL 3.267 4.960 OUTPUT VOL QUIESCENT CURRENT (µA) 20 3.256 4.940 10 VIN = 6V 3.245 ALL OTHER PINS = 0V 4.920 0 3.234 4.900 –75 –50 –25 0 25 50 75 100 125 150 175 –75 –50 –25 0 25 50 75 100 125 150 175 –75 –50 –25 0 25 50 75 100 125 150 175 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) LT3063 G05 LT3063 G06 3063 G04
LT3063 ADJ Pin Voltage LT3063-3.3 Quiescent Current LT3063–3.3 Quiescent Current LT3063-5 Quiescent Current LT3063–5 Quiescent Current
612 250 250 I 610 L = 1mA 225 225 608 200 200 606 175 175 604 602 150 150 TAGE (mV) 600 125 125 598 100 100 596 ADJ PIN VOL 75 75 594 VSHDN = VIN V QUIESCENT CURRENT (µA) SHDN = VIN 50 QUIESCENT CURRENT (µA) 50 592 590 25 25 VSHDN = 0V VSHDN = 0V 588 0 0 –75 –50 –25 0 25 50 75 100 125 150 175 0 1 2 3 4 5 6 7 8 9 10 11 12 0 1 2 3 4 5 6 7 8 9 10 11 12 TEMPERATURE (°C) VIN (V) VIN (V) 3063 G08 3063 G09 3063 G07 3063fa For more information www.linear.com/LT3063 5 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Package Description Revision History Typical Application Related Parts
