Datasheet LT3063 (Analog Devices) - 6
Description | 45V VIN, Micropower, Low Noise, 200mA LDO with Active Output Discharge |
Pages / Page | 22 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. … |
File Format / Size | PDF / 975 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Quiescent Current. LT3063-3.3 GND Pin Current
LT3063 Series
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Quiescent Current LT3063-3.3 GND Pin Current LT3063-5 GND Pin Current LT3063-5 GND Pin Current
120 T 5.0 5.0 110 J = 25°C VOUT = 5V 4.5 R 4.5 RL = 25Ω, IL = 200mA 100 I L = 16.5Ω, IL = 200mA L = 10μA 4.0 4.0 90 80 3.5 3.5 70 3.0 3.0 60 2.5 2.5 50 2.0 RL = 33Ω, IL = 100mA 2.0 RL = 50Ω, IL = 100mA 40 1.5 1.5 QUIESCENT CURRENT (µA) 30 GND PIN CURRENT (mA) GND PIN CURRENT (mA) R R 20 1.0 L = 66Ω, IL = 50mA 1.0 L = 100Ω, IL = 50mA 10 V 0.5 0.5 SHDN = 0V, RL = 0 R RL = 5kΩ, IL = 1mA 0 L = 3.3kΩ, IL = 1mA 0 0 0 5 10 15 20 25 30 35 40 45 0 1 2 3 4 5 6 7 8 9 10 11 12 0 1 2 3 4 5 6 7 8 9 10 11 12 VIN (V) VIN (V) VIN (V) 3063 G11 3063 G12 3063 G10
GND Pin Current, VOUT = 0.6V GND Pin Current vs ILOAD SHDN Pin Threshold
5.0 10 1.5 VIN = VOUT(NOMINAL) +1V 1.4 4.5 RL = 3Ω, IL = 200mA 9 1.3 4.0 8 1.2 1.1 3.5 7 1.0 3.0 6 0.9 OFF TO ON 0.8 2.5 5 0.7 R 2.0 L = 6Ω, IL = 100mA 4 0.6 ON TO OFF PIN THRESHOLD (V) 0.5 1.5 3 GND PIN CURRENT (mA) 0.4 R GND PIN CURRENT (mA) L = 12Ω, IL = 50mA 1.0 2 SHDN 0.3 0.2 0.5 1 RL = 600Ω, IL = 1mA 0.1 0 0 0 0 1 2 3 4 5 6 7 8 9 10 0 25 50 75 100 125 150 175 200 –75 –50 –25 0 25 50 75 100 125 150 175 VIN (V) ILOAD (mA) TEMPERATURE (°C) 3063 G13 3063 G14 3063 G15
SHDN Pin Input Current SHDN Pin Input Current ADJ Pin Bias Current
3.0 3.0 50 SHDN = 45V 40 2.5 2.5 30 20 2.0 2.0 10 1.5 1.5 0 –10 1.0 1.0 PIN INPUT CURRENT (µA) PIN INPUT CURRENT (µA) –20 ADJ PIN BIAS CURRENT (nA) SHDN –30 0.5 SHDN 0.5 –40 0 0 –50 0 5 10 15 20 25 30 35 40 45 –75 –50 –25 0 25 50 75 100 125 150 175 –75 –50 –25 0 25 50 75 100 125 150 175 SHDN PIN VOLTAGE (V) TEMPERATURE (°C) TEMPERATURE (°C) 3063 G16 3063 G17 3063 G18 3063fa 6 For more information www.linear.com/LT3063 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Package Description Revision History Typical Application Related Parts
