Datasheet AD4020 (Analog Devices) - 2
Description20-Bit, 1.8 MSPS, Precision SAR, Differential ADC
Pages / Page37 / 2 — AD4020* PRODUCT PAGE QUICK LINKS Last Content Update: 08/23/2017. …
File Format / SizePDF / 802 Kb
AD4020* PRODUCT PAGE QUICK LINKS Last Content Update: 08/23/2017. COMPARABLE PARTS. REFERENCE DESIGNS. EVALUATION KITS
AD4020* PRODUCT PAGE QUICK LINKS Last Content Update: 08/23/2017 COMPARABLE PARTS REFERENCE DESIGNS EVALUATION KITS
View a parametric search of comparable parts. • CN0385
EVALUATION KITS DESIGN RESOURCES
• Evaluation Board for the AD4000 Series 16-/18-/20-Bit • AD4020 Material Declaration Precision SAR ADCs • PCN-PDN Information • Quality And Reliability
DOCUMENTATION
• Symbols and Footprints
Data Sheet
• AD4020: 20-Bit, 1.8 MSPS, Precision SAR, Differential ADC
DISCUSSIONS
Data Sheet View all AD4020 EngineerZone Discussions.
User Guides
• UG-1042: Evaluation Board for the AD4000 Series 16-/18-
SAMPLE AND BUY
Bit Precision SAR ADCs Visit the product page to see pricing options.
SOFTWARE AND SYSTEMS REQUIREMENTS TECHNICAL SUPPORT
• AD4000 Series FPGA Device Driver Submit a technical question or find your regional support number.
TOOLS AND SIMULATIONS
• AD4000 Series IBIS Models
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION TRANSFER FUNCTIONS APPLICATIONS INFORMATION TYPICAL APPLICATION DIAGRAMS ANALOG INPUTS Input Overvoltage Clamp Circuit Differential Input Considerations Switched Capacitor Input RC Filter Values DRIVER AMPLIFIER CHOICE Single to Differential Driver High Frequency Input Signals Multiplexed Applications EASE OF DRIVE FEATURES Input Span Compression High-Z Mode Long Acquisition Phase VOLTAGE REFERENCE INPUT POWER SUPPLY DIGITAL INTERFACE REGISTER READ/WRITE FUNCTIONALITY STATUS WORD /CS MODE, 3-WIRE TURBO MODE /CS MODE, 3-WIRE WITHOUT THE BUSY INDICATOR /CS MODE, 3-WIRE WITH THE BUSY INDICATOR /CS MODE, 4-WIRE TURBO MODE /CS MODE, 4-WIRE WITHOUT THE BUSY INDICATOR /CS MODE, 4-WIRE WITH THE BUSY INDICATOR DAISY-CHAIN MODE LAYOUT GUIDELINES EVALUATING THE AD4020 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
