Datasheet AD7091R-5 (Analog Devices) - 7
Description4-Channel, I2C, Ultralow Power 12-Bit ADC in 20-Lead LFCSP/TSSOP
Pages / Page35 / 7 — AD7091R-5. Data Sheet. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. …
File Format / SizePDF / 845 Kb
AD7091R-5. Data Sheet. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 3. Parameter. Rating. Table 4. Thermal Resistance
AD7091R-5 Data Sheet ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 3 Parameter Rating Table 4 Thermal Resistance
T
THERMAL RESISTANCE
A = 25°C, unless otherwise noted. θ
Table 3.
JA is specified for the worst case conditions, that is, a device soldered in a circuit board for surface-mount packages.
Parameter Rating
VDD to GND −0.3 V to +7 V
VDRIVE to GND −0.3 V to +7 V
Package Type θJA θJC Unit
Analog Input Voltage to GND −0.3 V to VREF + 0.3 V 20-Lead LFCSP_WQ 52 6.5 °C/W Digital Input1 Voltage to GND −0.3 V to VDRIVE + 0.3 V 20-Lead TSSOP 84.3 18.4 °C/W Digital Output2 Voltage to GND −0.3 V to VDRIVE + 0.3 V Input Current to Any Pin Except Supplies3 ±10 mA
ESD CAUTION
Operating Temperature Range −40°C to +125°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C ESD Human Body Model (HBM) 1.5 kV Field Induced Charged Device 500 V Model (FICDM) 1 The digital input pins include the following: AS0, RESET, AS1, SCL, SDA, and CONVST/GPO1. 2 The digital output pins include: ALERT/BUSY/GPO0, GPO2, and SDA. 3 Transient currents of up to 100 mA do not cause SCR latch-up. Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. 0 | Page 6 of 34 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS I2C TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION ADC TRANSFER FUNCTION REFERENCE POWER SUPPLY DEVICE RESET ANALOG INPUT DRIVER AMPLIFIER CHOICE TYPICAL CONNECTION DIAGRAM I2C REGISTERS ADDRESSING REGISTERS SLAVE ADDRESS I2C REGISTER ACCESS CONVERSION RESULT REGISTER CHANNEL REGISTER CONFIGURATION REGISTER ALERT INDICATION REGISTER CHANNEL x LOW LIMIT REGISTER CHANNEL x HIGH LIMIT REGISTER CHANNEL x HYSTERESIS REGISTER I2C INTERFACE SERIAL BUS ADDRESS BYTE GENERAL I2C TIMING WRITING TO THE AD7091R-5 WRITING TWO BYTES OF DATA TO A 16-BIT REGISTER WRITING TO MULTIPLE REGISTERS READING DATA FROM THE AD7091R-5 READING TWO BYTES OF DATA FROM A 16-BIT REGISTER MODES OF OPERATION SAMPLE MODE COMMAND MODE AUTOCYCLE MODE POWER-DOWN MODE ALERT BUSY CHANNEL SEQUENCER OUTLINE DIMENSIONS ORDERING GUIDE
