Datasheet AD9681 (Analog Devices) - 5
DescriptionOctal, 14-Bit, 125 MSPS, Serial LVDS, 1.8 V Analog-to-Digital Converter
Pages / Page41 / 5 — AD9681. Data Sheet. SPECIFICATIONS DC SPECIFICATIONS. Table 1. Parameter1 …
RevisionC
AD9681. Data Sheet. SPECIFICATIONS DC SPECIFICATIONS. Table 1. Parameter1 Temp. Min. Typ. Max. Unit
AD9681 Data Sheet SPECIFICATIONS DC SPECIFICATIONS Table 1 Parameter1 Temp Min Typ Max Unit
AVDD = 1.8 V, DRVDD = 1.8 V, 2 V p-p differential input, 1.0 V internal reference, AIN = −1.0 dBFS, unless otherwise noted.
Table 1. Parameter1 Temp Min Typ Max Unit
RESOLUTION 14 Bits ACCURACY No Missing Codes Full Guaranteed Offset Error Full −0.23 +0.21 +0.62 % FSR Offset Matching Full 0 0.24 0.7 % FSR Gain Error Full −8.0 −3.1 +1.7 % FSR Gain Matching Full 0 1.8 6.0 % FSR Differential Nonlinearity (DNL) Full −0.92 ±0.8 +1.75 LSB Integral Nonlinearity (INL) Full −4.0 ±1.2 +4.0 LSB TEMPERATURE DRIFT Offset Error Full −4 ppm/°C Gain Error Full 38 ppm/°C INTERNAL VOLTAGE REFERENCE Output Voltage (1 V Mode) Full 0.98 1.0 1.02 V Load Regulation at 1.0 mA (VREF = 1 V) 25°C 3 mV Input Resistance Full 7.5 kΩ INPUT-REFERRED NOISE VREF = 1.0 V 25°C 0.99 LSB rms ANALOG INPUTS Differential Input Voltage (VREF = 1 V) Full 2 V p-p Common-Mode Voltage Full 0.5 0.9 1.3 V Differential Input Resistance Full 5.2 kΩ Differential Input Capacitance Full 3.5 pF POWER SUPPLY AVDD Full 1.7 1.8 1.9 V DRVDD Full 1.7 1.8 1.9 V IAVDD Full 368 423 mA IDRVDD (ANSI-644 Mode) Full 120 126 mA IDRVDD (Reduced Range Mode) 25°C 90 mA TOTAL POWER CONSUMPTION Total Power Dissipation (Eight Channels, Including Output Drivers Full 879 988 mW ANSI-644 Mode) Total Power Dissipation (Eight Channels, Including Output Drivers 25°C 825 mW Reduced Range Mode) Power-Down Dissipation 25°C 2 mW Standby Dissipation2 25°C 485 mW 1 See the AN-835 Application Note, Understanding High Speed ADC Testing and Evaluation, for definitions and for information about how these tests were completed. 2 Controlled via the SPI. Rev. C | Page 4 of 40 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION SIMPLIFIED FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ANALOG INPUT CONSIDERATIONS Input Common Mode Differential Input Configurations VOLTAGE REFERENCE Internal Reference Connection External Reference Operation CLOCK INPUT CONSIDERATIONS Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations POWER DISSIPATION AND POWER-DOWN MODE DIGITAL OUTPUTS AND TIMING SDIO/OLM Pin SCLK/DTP Pin CSB1 and CSB2 Pins RBIAS1 and RBIAS2 Pins OUTPUT TEST MODES SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Open Locations Default Values Logic Levels Channel Specific Registers MEMORY MAP MEMORY MAP REGISTER DESCRIPTIONS Device Index (Register 0x05) Transfer (Register 0xFF) Power Modes (Register 0x08) Enhancement Control (Register 0x0C) Output Mode (Register 0x14) Output Adjust (Register 0x15) Output Phase (Register 0x16) Serial Output Data Control (Register 0x21) Resolution/Sample Rate Override (Register 0x100) User I/O Control 2 (Register 0x101) User I/O Control 3 (Register 0x102) APPLICATIONS INFORMATION DESIGN GUIDELINES POWER AND GROUND RECOMMENDATIONS BOARD LAYOUT CONSIDERATIONS Sources of Coupling Crosstalk Between Inputs Coupling of Digital Output Switching Noise to Analog Inputs and Clock CLOCK STABILITY CONSIDERATIONS VCM REFERENCE DECOUPLING SPI PORT OUTLINE DIMENSIONS ORDERING GUIDE
