Datasheet AD9653 (Analog Devices) - 2
DescriptionQuad, 16-Bit, 125 MSPS Serial LVDS 1.8 V Analog-to-Digital Converter
Pages / Page42 / 2 — AD9653* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionF
AD9653* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Press. EVALUATION KITS
AD9653* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Press EVALUATION KITS
View a parametric search of comparable parts.
Press
• Four-channel, 16-bit, 125-MSPS Analog-to-Digital
EVALUATION KITS
Converter Delivers Superior Dynamic Performance and Industry’s Lowest Power and Package-size for its Class. • AD9653 Evaluation Board
Technical Articles DOCUMENTATION
• MS-2210: Designing Power Supplies for High Speed ADC
Application Notes Tutorials
• AN-1142: Techniques for High Speed ADC PCB Layout • MT-230: Noise Considerations in High Speed Converter Signal Chains • AN-835: Understanding High Speed ADC Testing and Evaluation
DESIGN RESOURCES
• AN-905: Visual Analog Converter Evaluation Tool Version 1.0 User Manual • AD9653 Material Declaration • AN-935: Designing an ADC Transformer-Coupled Front • PCN-PDN Information End • Quality And Reliability
Data Sheet
• Symbols and Footprints • AD9653: Quad, 16-Bit, 125 MSPS, Serial LVDS 1.8 V Analog-to-Digital Converter Data Sheet
DISCUSSIONS User Guides
View all AD9653 EngineerZone Discussions. • Evaluating the AD9253/AD9633/AD9653 Analog-to- Digital Converters
SAMPLE AND BUY
Visit the product page to see pricing options.
TOOLS AND SIMULATIONS
• Visual Analog
TECHNICAL SUPPORT
• AD9653 IBIS Model Submit a technical question or find your regional support • AD9653 Input Impedance number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS VREF = 1.0 V VREF = 1.3 V EQUIVALENT CIRCUITS THEORY OF OPERATION ANALOG INPUT CONSIDERATIONS Input Common Mode Differential Input Configurations VOLTAGE REFERENCE Internal Reference Connection External Reference Operation CLOCK INPUT CONSIDERATIONS Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations POWER DISSIPATION AND POWER-DOWN MODE DIGITAL OUTPUTS AND TIMING SDIO/OLM Pin SCLK/DTP Pin CSB Pin RBIAS Pin OUTPUT TEST MODES SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Open Locations Default Values Logic Levels Channel-Specific Registers MEMORY MAP REGISTER TABLE MEMORY MAP REGISTER DESCRIPTIONS Device Index (Register 0x04, Register 0x05) Transfer (Register 0xFF) Power Modes (Register 0x08) Bits[7:6]—Open Bit 5—External Power-Down Pin Function Bits[4:2]—Open Bits[1:0]—Power Mode Clock (Register 0x09) Bits[7:1]—Open Bit 0—Duty Cycle Stabilize Enhancement Control (Register 0x0C) Bits[7:3]—Open Bit 2—Chop Mode Bits[1:0]—Open Output Mode (Register 0x14) Bit 7—Open Bit 6—LVDS-ANSI/LVDS-IEEE Option Bits[5:3]—Open Bit 2—Output Invert Bit 1—1 Bit 0—Output Format Output Adjust (Register 0x15) Bits[7:6]—Open Bits[5:4]—Output Driver Termination Bits[3:1]—Open Bit 0—Output Drive Output Phase (Register 0x16) Bit 7—Open Bits[6:4]—Input Clock Phase Adjust Bits[3:0]—Output Clock Phase Adjust Serial Output Data Control (Register 0x21) Sample Rate Override (Register 0x100) User Input/Output Control 2 (Register 0x101) Bits[7:1]—Open Bit 0—SDIO Pull-Down User Input/Output Control 3 (Register 0x102) Bits[7:4]—Open Bit 3—VCM Power-Down Bits[2:0]—Open APPLICATIONS INFORMATION DESIGN GUIDELINES POWER AND GROUND RECOMMENDATIONS CLOCK STABILITY CONSIDERATIONS EXPOSED PAD THERMAL HEAT SLUG RECOMMENDATIONS VCM REFERENCE DECOUPLING SPI PORT CROSSTALK PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
