Datasheet HMCAD1511 (Analog Devices)
DescriptionHigh Speed Multi-Mode 8-Bit 1 GSPS A/D Converter
Pages / Page31 / 1 — HMCAD1511. HigH Speed Multi-Mode 8-Bit. 30 MSpS to 1 gSpS A/d Converter. …
HMCAD1511. HigH Speed Multi-Mode 8-Bit. 30 MSpS to 1 gSpS A/d Converter. Features. typical Applications. pin compatible parts
Datasheet HMCAD1511 Analog Devices
HMCAD1511
v04.1015
HigH Speed Multi-Mode 8-Bit 30 MSpS to 1 gSpS A/d Converter Features
• 8-bit High speed single/ Dual/ Quad ADC • Internal offset Correction single Channel Mode: Fsmax = 1000 MsPs • 1.8v supply voltage Dual Channel Mode: Fsmax = 500 MsPs Quad Channel Mode: Fsmax = 250 MsPs • 1.7 - 3.6v CMos Logic on Control Interface Pins • Integrated Cross Point switches (Mux Array) • serial LvDs/rsDs output • 1X to 50X Digital Gain • 7x7 mm QFn 48 (LP7D) Package no Missing Codes up to 32X
• 1X Gain: 49.8 dB snr. 10X Gain: 48 dB snr • Internal Low Jitter Programmable Clock Divider • UsB Powered oscil oscopes • Ultra Low Power Dissipation • Digital oscil oscopes 0 710 mW including I/o at 1000 MsPs • satel ite receivers • 0.5 µs start-up time from sleep,
15 µs from Power Down • Internal reference Circuitry with no • HMCAD1511 is pin compatible with HMCAD1520 t external Components required • HMCAD1511 is pin compatible and can be M • Coarse and Fine Gain Control configured to operate as HMCAD1510, with s functionality and performance as described • Digital Fine Gain Adjustment for each ADC in HMCAD1510 datasheet s - r
Functional diagram
e t r e v n o /D C A Figure 1. Functional Block Diagram Information n furnis is hed d by y Anal al og g Devices s is s believed d to o be e acc cc urate e and d re re liabl bl e. Howe we ver, no o For p r p rice, d , d elivery, a , a nd t d t o p o p lace o e o rd rd e e rrs s : A : A n n a allo o g D g D ev eviic c e e s s , I , I n n c c .., responsibility i y i s a s a ssumed b d b y A y A nal al og D g D evices f s f or i r i ts u s u se se , n , o no r f r f or a r a ny i y i nfringem em en en ts o s o f p f p aten en ts o s o r o r o ther One Technol ol ogy Way, P.O. Box 9106, Norwood, MA 02 2 0 0 6 6 2 2 --9 9 1 1 0 0 6 rights of third parties that may result from its use. Specifications subject to change without notice. No 6
0 - 1
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Ord rd er online at w t w ww w.an n a allog og ..c c o o m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. m Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
