AD9262* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017COMPARABLE PARTSTOOLS AND SIMULATIONS View a parametric search of comparable parts. • AD9262 IBIS Model EVALUATION KITSREFERENCE MATERIALS • AD9262 Evaluation Board Technical Articles • MS-2210: Designing Power Supplies for High Speed ADC DOCUMENTATION • Understanding Continuous-Time, Discrete-Time Sigma- Application Notes Delta ADCs And Nyquist ADCs • AN-1142: Techniques for High Speed ADC PCB Layout • AN-282: Fundamentals of Sampled Data Systems DESIGN RESOURCES • AN-283: Sigma-Delta ADCs and DACs • AD9262 Material Declaration • AN-807: Multicarrier WCDMA Feasibility • PCN-PDN Information • AN-808: Multicarrier CDMA2000 Feasibility • Quality And Reliability • AN-812: MicroController-Based Serial Port Interface (SPI) • Symbols and Footprints Boot Circuit • AN-835: Understanding High Speed ADC Testing and DISCUSSIONS Evaluation View all AD9262 EngineerZone Discussions. • AN-878: High Speed ADC SPI Control Software • AN-905: Visual Analog Converter Evaluation Tool Version SAMPLE AND BUY 1.0 User Manual Visit the product page to see pricing options. • Interfacing the ADL5382 Quadrature I/Q Demodulator to the AD9262 16-Bit Continuous Time Sigma-Delta ADC as TECHNICAL SUPPORT an RF-to-Bits Solution Submit a technical question or find your regional support Data Sheet number. • AD9262: 16-Bit, 2.5 MHz/5 MHz/10 MHz, 30 MSPS to 160 MSPS Dual Continuous Time Sigma-Delta ADC Data Sheet DOCUMENT FEEDBACKUser Guides Submit feedback for this data sheet. • UG-051: Evaluating the AD9262, 16-Bit, Dual Continuous Time Sigma Delta ADC and Demonstrating Direct Conversion This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified. Document Outline Features Applications General Description Functional Block Diagram Product Highlights Revision History Specifications DC Specifications AC Specifications Digital Decimation Filtering Characteristics Digital Specifications Switching Specifications Timing Diagram Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics AD9262BCPZ AD9262BCPZ-5 AD9262BCPZ-10 Equivalent Circuits Theory of Operation Analog Input Considerations Input Common Mode Differential Input Configurations Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Direct Clocking Internal PLL Clock Distribution PLL Autoband Select Jitter Considerations Power Dissipation and Standby Mode Digital Engine Bandwidth Selection Decimation Filters Sample Rate Converter Cascaded Filter Responses DC and Quadrature Error Correction (QEC) LO Leakage (DC) Correction QEC and DC Correction Range Digital Outputs Digital Output Format Interleaved Outputs Overrange (OR) Condition Timing Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface Applications Information Filtering Requirement Memory Map Memory Map Definitions Outline Dimensions Ordering Guide
