Datasheet AD9262 (Analog Devices) - 3
Description16-Bit, 2.5 MHz/5 MHz/10 MHz, 30 MSPS to 160 MSPS Dual Continuous Time Sigma-Delta ADC
Pages / Page33 / 3 — AD9262. TABLE OF CONTENTS. REVISION HISTORY. 2/10—Rev. 0 to Rev. A. …
RevisionA
AD9262. TABLE OF CONTENTS. REVISION HISTORY. 2/10—Rev. 0 to Rev. A. 1/10—Revision 0: Initial Version
AD9262 TABLE OF CONTENTS REVISION HISTORY 2/10—Rev 0 to Rev A 1/10—Revision 0: Initial Version
link to page 1 link to page 1 link to page 1 link to page 1 link to page 1 link to page 3 link to page 4 link to page 4 link to page 5 link to page 6 link to page 7 link to page 8 link to page 9 link to page 9 link to page 9 link to page 10 link to page 11 link to page 11 link to page 12 link to page 13 link to page 16 link to page 17 link to page 17 link to page 19 link to page 21 link to page 22 link to page 24 link to page 25 link to page 26 link to page 27 link to page 27 link to page 28 link to page 29 link to page 29 link to page 31 link to page 31 link to page 33 link to page 33
Features .. 1  AD9262BCPZ-10 ... 12  Applications ... 1  Equivalent Circuits ... 15  General Description ... 1  Theory of Operation .. 16  Functional Block Diagram .. 1  Analog Input Considerations ... 16  Product Highlights ... 1  Clock Input Considerations .. 18  Revision History ... 2  Power Dissipation and Standby Mode .. 20  Specifications ... 3  Digital Engine ... 21  DC Specifications ... 3  DC and Quadrature Error Correction (QEC) .. 23  AC Specifications .. 4  Digital Outputs ... 24  Digital Decimation Filtering Characteristics .. 5  Timing ... 25  Digital Specifications ... 6  Serial Port Interface (SPI) .. 26  Switching Specifications .. 7  Configuration Using the SPI ... 26  Absolute Maximum Ratings .. 8  Hardware Interface ... 27  Thermal Resistance .. 8  Applications Information .. 28  ESD Caution .. 8  Filtering Requirement .. 28  Pin Configuration and Function Descriptions ... 9  Memory Map .. 30  Typical Performance Characteristics ... 10  Memory Map Definitions ... 30  AD9262BCPZ ... 10  Outline Dimensions ... 32  AD9262BCPZ-5 .. 11  Ordering Guide .. 32
REVISION HISTORY 2/10—Rev. 0 to Rev. A
Changes to Figure 61 .. 28
Rev. A | Page 2 of 32 Document Outline Features Applications General Description Functional Block Diagram Product Highlights Revision History Specifications DC Specifications AC Specifications Digital Decimation Filtering Characteristics Digital Specifications Switching Specifications Timing Diagram Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics AD9262BCPZ AD9262BCPZ-5 AD9262BCPZ-10 Equivalent Circuits Theory of Operation Analog Input Considerations Input Common Mode Differential Input Configurations Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Direct Clocking Internal PLL Clock Distribution PLL Autoband Select Jitter Considerations Power Dissipation and Standby Mode Digital Engine Bandwidth Selection Decimation Filters Sample Rate Converter Cascaded Filter Responses DC and Quadrature Error Correction (QEC) LO Leakage (DC) Correction QEC and DC Correction Range Digital Outputs Digital Output Format Interleaved Outputs Overrange (OR) Condition Timing Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface Applications Information Filtering Requirement Memory Map Memory Map Definitions Outline Dimensions Ordering Guide
