AD9649* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017COMPARABLE PARTSTOOLS AND SIMULATIONS View a parametric search of comparable parts. • Visual Analog • AD9649 IBIS Models EVALUATION KITS • AD9649 Evaluation Board REFERENCE MATERIALSSolutions Bulletins & BrochuresDOCUMENTATION • Analog-to-Digital Converter and Drivers ICs Solutions Application Notes Bulletin, Volume 10, Issue 2 • AN-1142: Techniques for High Speed ADC PCB Layout Technical Articles • AN-586: LVDS Outputs for High Speed A/D Converters • Improve The Design Of Your Passive Wideband ADC Front-End Network • AN-742: Frequency Domain Response of Switched- Capacitor ADCs • MS-2210: Designing Power Supplies for High Speed ADC • AN-807: Multicarrier WCDMA Feasibility • AN-808: Multicarrier CDMA2000 Feasibility DESIGN RESOURCES • AN-812: MicroController-Based Serial Port Interface (SPI) • AD9649 Material Declaration Boot Circuit • PCN-PDN Information • AN-827: A Resonant Approach to Interfacing Amplifiers to • Quality And Reliability Switched-Capacitor ADCs • Symbols and Footprints • AN-878: High Speed ADC SPI Control Software • AN-935: Designing an ADC Transformer-Coupled Front DISCUSSIONS End View all AD9649 EngineerZone Discussions. Data Sheet • AD9649: 14-Bit, 20/40/65/80 MSPS, 1.8 V Analog-to-Digital SAMPLE AND BUY Converter Data Sheet Visit the product page to see pricing options. User Guides • Evaluating the AD9266/AD9649/AD9629/AD9609 Analog- TECHNICAL SUPPORT to-Digital Converters Submit a technical question or find your regional support number. SOFTWARE AND SYSTEMS REQUIREMENTS • FMC Interposer & Xilinx KC705 Reference Design DOCUMENT FEEDBACK Submit feedback for this data sheet. This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified. Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS AD9649-80 AD9649-65 AD9649-40 AD9649-20 EQUIVALENT CIRCUITS THEORY OF OPERATION ANALOG INPUT CONSIDERATIONS Input Common Mode Differential Input Configurations Single-Ended Input Configuration VOLTAGE REFERENCE Internal Reference Connection External Reference Operation CLOCK INPUT CONSIDERATIONS Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations POWER DISSIPATION AND STANDBY MODE DIGITAL OUTPUTS Digital Output Enable Function (OEB) TIMING Data Clock Output (DCO) BUILT-IN SELF-TEST (BIST) AND OUTPUT TEST BUILT-IN SELF-TEST (BIST) OUTPUT TEST MODES SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE OPEN LOCATIONS DEFAULT VALUES Logic Levels Transfer Register Map MEMORY MAP REGISTER TABLE MEMORY MAP REGISTER DESCRIPTIONS USR2 (Register 0x101) Bit 3—Enable GCLK Detect Bit 2—Run GCLK Bit 0—Disable SDIO Pull-Down APPLICATIONS INFORMATION DESIGN GUIDELINES Power and Ground Recommendations Exposed Paddle Thermal Heat Sink Recommendations Encode Clock VCM RBIAS Reference Decoupling SPI Port Soft Reset OUTLINE DIMENSIONS ORDERING GUIDE
