Datasheet AD9230-11 (Analog Devices) - 8 Manufacturer Analog Devices Description 11-Bit, 200 MSPS, 1.8 V Analog-to-Digital Converter Pages / Page 29 / 8 — AD9230-11. TIMING DIAGRAMS. N – 1. N + 4. N + 5. N + 3. VIN. N + 1. N + … File Format / Size PDF / 665 Kb Document Language English
AD9230-11. TIMING DIAGRAMS. N – 1. N + 4. N + 5. N + 3. VIN. N + 1. N + 2. tCH. tCL. 1/fS. CLK+. CLK–. tCPD. DCO+. DCO–. tSKEW. tPD. Dx+. N – 6. N – 5. N – 4. N – 3
Model Line for this Datasheet Text Version of Document AD9230-11 TIMING DIAGRAMS N – 1 t N + 4 A N + 5 N N + 3 VIN N + 1 N + 2 tCH tCL 1/fS CLK+ CLK– tCPD DCO+ DCO– tSKEW tPD Dx+ N – 6 N – 5 N – 4 N – 3 N – 2 02 0Dx– 1- 10 07 Figure 2. Single Data Rate ModeN – 1 t N + 4 A N + 5 N N + 3 VIN N + 1 N + 2 tCH tCL 1/fS CLK+ CLK– tCPD DCO+ DCO– tSKEW tPD D5+ D5 NO D5 NO D5 NO D5 NO D5 NO N – 7 DATA N – 6 DATA N – 5 DATA N – 4 DATA N – 3 DATA D5– D4/D10+ D10 D4 D10 D4 D10 D4 D10 D4 D10 D4 N – 7 N – 6 N – 6 N – 5 N – 5 N – 4 N – 4 N – 3 N – 3 N – 2 D4/D10– 36 MSBs 00 1-5 LSBs 10 07 Figure 3. Double Data Rate Mode Rev. 0 | Page 7 of 28 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ANALOG INPUT AND VOLTAGE REFERENCE Differential Input Configurations CLOCK INPUT CONSIDERATIONS Clock Duty Cycle Considerations Clock Jitter Considerations POWER DISSIPATION AND POWER-DOWN MODE DIGITAL OUTPUTS Digital Outputs and Timing Output Data Rate and Pinout Configuration Out-of-Range (OR) TIMING RBIAS CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI MEMORY MAP READING THE MEMORY MAP TABLE RESERVED LOCATIONS DEFAULT VALUES LOGIC LEVELS TRANSFER REGISTER MAP OUTLINE DIMENSIONS ORDERING GUIDE
