Datasheet AD9246 (Analog Devices) - 2
Description14-Bit, 80 MSPS/105 MSPS/125 MSPS, 1.8 V Analog-to-Digital Converter
Pages / Page45 / 2 — AD9246* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. …
AD9246* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9246* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
View a parametric search of comparable parts. • Visual Analog • AD9246 IBIS Models
EVALUATION KITS
• AD9246 Evaluation Board
REFERENCE DESIGNS
• CN0051
DOCUMENTATION Application Notes REFERENCE MATERIALS
• AN-1142: Techniques for High Speed ADC PCB Layout
Technical Articles
• AN-1408: Using the AD8376 VGA to Drive Wide • Improve The Design Of Your Passive Wideband ADC Bandwidth ADCs for High IF AC-Coupled Applications Front-End Network • AN-282: Fundamentals of Sampled Data Systems • Matching An ADC To A Transformer • AN-345: Grounding for Low-and-High-Frequency Circuits • MS-2210: Designing Power Supplies for High Speed ADC • AN-501: Aperture Uncertainty and ADC System Performance
DESIGN RESOURCES
• AN-715: A First Approach to IBIS Models: What They Are • AD9246 Material Declaration and How They Are Generated • PCN-PDN Information • AN-737: How ADIsimADC Models an ADC • Quality And Reliability • AN-741: Little Known Characteristics of Phase Noise • Symbols and Footprints • AN-742: Frequency Domain Response of Switched- Capacitor ADCs
DISCUSSIONS
• AN-756: Sampled Systems and the Effects of Clock Phase Noise and Jitter View all AD9246 EngineerZone Discussions. • AN-807: Multicarrier WCDMA Feasibility
SAMPLE AND BUY
• AN-808: Multicarrier CDMA2000 Feasibility Visit the product page to see pricing options. • AN-812: MicroController-Based Serial Port Interface (SPI) Boot Circuit
TECHNICAL SUPPORT
• AN-827: A Resonant Approach to Interfacing Amplifiers to Switched-Capacitor ADCs Submit a technical question or find your regional support • AN-835: Understanding High Speed ADC Testing and number. Evaluation • AN-851: A WiMax Double Downconversion IF Sampling
DOCUMENT FEEDBACK
Receiver Design Submit feedback for this data sheet. • AN-878: High Speed ADC SPI Control Software • AN-905: Visual Analog Converter Evaluation Tool Version 1.0 User Manual • AN-935: Designing an ADC Transformer-Coupled Front End
Data Sheet
• AD9246: 14-Bit, 80 MSPS/105 MSPS/125 MSPS, 1.8 V Analog-to-Digital Converter Data Sheet
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAM ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ANALOG INPUT CONSIDERATIONS VOLTAGE REFERENCE CLOCK INPUT CONSIDERATIONS JITTER CONSIDERATIONS POWER DISSIPATION AND STANDBY MODE DIGITAL OUTPUTS TIMING SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI MEMORY MAP READING THE MEMORY MAP REGISTER TABLE MEMORY MAP REGISTER TABLE LAYOUT CONSIDERATIONS POWER AND GROUND RECOMMENDATIONS CML RBIAS REFERENCE DECOUPLING EVALUATION BOARD POWER SUPPLIES INPUT SIGNALS OUTPUT SIGNALS DEFAULT OPERATION AND JUMPER SELECTION SETTINGS ALTERNATIVE CLOCK CONFIGURATIONS ALTERNATIVE ANALOG INPUT DRIVE CONFIGURATION SCHEMATICS EVALUATION BOARD LAYOUTS BILL OF MATERIALS OUTLINE DIMENSIONS ORDERING GUIDE
