Datasheet AD7453 (Analog Devices) - 7
DescriptionPseudo Differential, 555 kSPS, 12-Bit A/D Converter in 8-Lead SOT-23
Pages / Page21 / 7 — AD7453. ABSOLUTE MAXIMUM RATINGS. 1.6mA. IOL. Table 3. Parameter Rating. …
File Format / SizePDF / 429 Kb
AD7453. ABSOLUTE MAXIMUM RATINGS. 1.6mA. IOL. Table 3. Parameter Rating. TO OUTPUT. 1.6V. PIN. 25pF. 200. IOH. ESD CAUTION
AD7453 ABSOLUTE MAXIMUM RATINGS 1.6mA IOL Table 3 Parameter Rating TO OUTPUT 1.6V PIN 25pF 200 IOH ESD CAUTION
link to page 7
1.6mA IOL Table 3. Parameter Rating TO OUTPUT 1.6V
VDD to GND –0.3 V to +7 V
PIN CL
V
25pF
IN+ to GND –0.3 V to VDD + 0.3 V -003 VIN– to GND –0.3 V to VDD + 0.3 V
200
µ
A IOH
Digital Input Voltage to GND –0.3 V to +7 V 03155-A Digital Output Voltage to GND –0.3 V to VDD + 0.3 V Figure 3. Load Circuit for Digital Output Timing Specifications VREF to GND –0.3 V to VDD + 0.3 V Input Current to Any Pin Except Supplies1 ±10 mA Operating Temperature Range Commercial (A, B Version) –40°C to +85°C Storage Temperature Range –65°C to +85°C Junction Temperature 150°C θJA Thermal Impedance 211.5°C/W (SOT-23) θJC Thermal Impedance 91.99°C/W (SOT-23) Lead Temperature, Soldering Vapor Phase (60 secs) 215°C Infrared (15 secs) 220°C ESD 1 kV Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those listed in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 1 Transient currents of up to 100 mA will not cause SCR latch-up.
ESD CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although this product features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality. Rev. B | Page 6 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY AD7453–TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT INFORMATION CONVERTER OPERATION ADC TRANSFER FUNCTION TYPICAL CONNECTION DIAGRAM THE ANALOG INPUT Analog Input Structure DIGITAL INPUTS REFERENCE SERIAL INTERFACE Timing Example 1 MODES OF OPERATION NORMAL MODE POWER-DOWN MODE POWER-UP TIME POWER VS. THROUGHPUT RATE MICROPROCESSOR AND DSP INTERFACING AD7453 to ADSP-21xx AD7453 to TMS320C5x/C54x AD7453 to DSP56xxx APPLICATION HINTS Grounding and Layout EVALUATING THE AD7453’S PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
