Datasheet AD7453 (Analog Devices) - 8
DescriptionPseudo Differential, 555 kSPS, 12-Bit A/D Converter in 8-Lead SOT-23
Pages / Page21 / 8 — AD7453. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. VDD 1. VREF. SCLK. …
File Format / SizePDF / 429 Kb
AD7453. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. VDD 1. VREF. SCLK. VIN+. SDATA. TOP VIEW. VIN–. (Not to Scale). GND
AD7453 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS VDD 1 VREF SCLK VIN+ SDATA TOP VIEW VIN– (Not to Scale) GND
AD7453 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS VDD 1 8 VREF SCLK 2 AD7453 7 VIN+ SDATA 3 TOP VIEW 6 VIN– (Not to Scale) CS 4 5 GND
03155-A-004 Figure 4. Pin Function Descriptions
Table 4. Pin Function Descriptions Mnemonic Function
VREF Reference Input for the AD7453. An external reference in the range 100 mV to VDD must be applied to this input. The specified reference input is 2.5 V. This pin should be decoupled to GND with a capacitor of at least 0.1 µF. VIN+ Noninverting Analog Input. VIN– Inverting Input. This pin sets the ground reference point for the VIN+ input. Connect to ground or to a dc offset to provide a pseudo ground. GND Analog Ground. Ground reference point for all circuitry on the AD7453. All analog input signals and any external reference signal should be referred to this GND voltage. CS Chip Select. Active low logic input. This input provides the dual function of initiating a conversion on the AD7453 and framing the serial data transfer. SDATA Serial Data. Logic output. The conversion result from the AD7453 is provided on this output as a serial data stream. The bits are clocked out on the falling edge of the SCLK input. The data stream of the AD7453 consists of four leading zeros followed by the 12 bits of conversion data that are provided MSB first. The output coding is straight (natural) binary. SCLK Serial Clock. Logic input. SCLK provides the serial clock for accessing data from the part. This clock input is also used as the clock source for the conversion process. VDD Power Supply Input. VDD is 2.7 V to 5.25 V. This supply should be decoupled to GND with a 0.1 µF capacitor and a 10 µF tantalum capacitor. Rev. B | Page 7 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY AD7453–TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT INFORMATION CONVERTER OPERATION ADC TRANSFER FUNCTION TYPICAL CONNECTION DIAGRAM THE ANALOG INPUT Analog Input Structure DIGITAL INPUTS REFERENCE SERIAL INTERFACE Timing Example 1 MODES OF OPERATION NORMAL MODE POWER-DOWN MODE POWER-UP TIME POWER VS. THROUGHPUT RATE MICROPROCESSOR AND DSP INTERFACING AD7453 to ADSP-21xx AD7453 to TMS320C5x/C54x AD7453 to DSP56xxx APPLICATION HINTS Grounding and Layout EVALUATING THE AD7453’S PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
