Datasheet AD7790 (Analog Devices) - 8
Description16-Bit, Single-Channel, Ultra Low Power, Sigma Delta A/D Converter
Pages / Page21 / 8 — Data Sheet. AD7790. ABSOLUTE MAXIMUM RATINGS. Table 3. (TA= 25°C, unless …
File Format / SizePDF / 471 Kb
Data Sheet. AD7790. ABSOLUTE MAXIMUM RATINGS. Table 3. (TA= 25°C, unless otherwise noted.) Parameter. Rating. ESD CAUTION
Data Sheet AD7790 ABSOLUTE MAXIMUM RATINGS Table 3 (TA= 25°C, unless otherwise noted.) Parameter Rating ESD CAUTION
Data Sheet AD7790 ABSOLUTE MAXIMUM RATINGS Table 3. (TA= 25°C, unless otherwise noted.) Parameter Rating
Stresses above those listed under Absolute Maximum Ratings VDD to GND –0.3 V to +7 V may cause permanent damage to the device. This is a stress Analog Input Voltage to GND –0.3 V to VDD + 0.3 V rating only; functional operation of the device at these or any Reference Input Voltage to GND –0.3 V to VDD + 0.3 V other conditions above those listed in the operational sections Total AIN/REFIN Current (Indefinite) 30 mA of this specification is not implied. Exposure to absolute Digital Input Voltage to GND –0.3 V to VDD + 0.3 V maximum rating conditions for extended periods may affect Digital Output Voltage to GND –0.3 V to VDD + 0.3 V device reliability. Operating Temperature Range –40°C to +105°C Storage Temperature Range –65°C to +150°C
ESD CAUTION
Maximum Junction Temperature 150°C MSOP θJA Thermal Impedance 206°C/W θJC Thermal Impedance 44°C/W Lead Temperature, Soldering (10 sec) 300°C IR Reflow, Peak Temperature 220°C Rev. A | Page 7 of 20 Document Outline AD7790—Specifications Timing Characteristics Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics On-Chip Registers Communications Register (RS1, RS0 = 0, 0) Status Register (RS1, RS0 = 0, 0; Power-on/Reset = 0x88) Mode Register (RS1, RS0 = 0, 1; Power-on/Reset = 0x02) Filter Register (RS1, RS0 = 1, 0; Power-on/Reset = 0x04) Data Register (RS1, RS0 = 1, 1; Power-on/Reset = 0x0000) ADC Circuit Information Overview Noise Performance Reduced Current Modes Digital Interface Single Conversion Mode Continuous Conversion Mode Continuous Read Mode Circuit Description Analog Input Channel Programmable Gain Amplifier Bipolar Configuration Data Output Coding Reference Input VDD Monitor Grounding and Layout Outline Dimensions Ordering Guide
