Datasheet AD9215 (Analog Devices) - 7
Description10-Bit, 65/80/105 MSPS 3 V A/D Converter
Pages / Page37 / 7 — AD9215. Data Sheet. ABSOLUTE MAXIMUM RATINGS1. Table 5. EXPLANATION OF …
RevisionB
AD9215. Data Sheet. ABSOLUTE MAXIMUM RATINGS1. Table 5. EXPLANATION OF TEST LEVELS. With. Mnemonic. Respect to. Min. Max. Unit. Test Level
AD9215 Data Sheet ABSOLUTE MAXIMUM RATINGS1 Table 5 EXPLANATION OF TEST LEVELS With Mnemonic Respect to Min Max Unit Test Level
link to page 7 link to page 7
AD9215 Data Sheet ABSOLUTE MAXIMUM RATINGS1 Table 5. EXPLANATION OF TEST LEVELS With Mnemonic Respect to Min Max Unit Test Level
ELECTRICAL I 100% production tested. AVDD AGND −0.3 +3.9 V DRVDD DRGND −0.3 +3.9 V II 100% production tested at 25°C and sample tested at spec- AGND DRGND −0.3 +0.3 V ified temperatures. AVDD DRVDD −3.9 +3.9 V Digital Outputs DRGND −0.3 DRVDD + 0.3 V III Sample tested only. CLK, MODE AGND −0.3 AVDD + 0.3 V IV Parameter is guaranteed by design and characterization VIN+, VIN− AGND −0.3 AVDD + 0.3 V testing. VREF AGND −0.3 AVDD + 0.3 V SENSE AGND −0.3 AVDD + 0.3 V V Parameter is a typical value only. REFB, REFT AGND −0.3 AVDD + 0.3 V PDWN AGND −0.3 AVDD + 0.3 V VI 100% production tested at 25°C; guaranteed by design and characterization testing for industrial temperature range; ENVIRONMENTAL2 100% production tested at temperature extremes for mili- Operating Temperature −40 +85 °C tary devices. Junction Temperature 150 °C Lead Temperature (10 sec) 300 °C Storage Temperature −65 +150 °C NOTES 1Absolute maximum ratings are limiting values to be applied individually, and beyond which the serviceability of the circuit may be impaired. Functional operability is not necessarily implied. Exposure to absolute maximum rating conditions for an extended period of time may affect device reliability. 2Typical thermal impedances 28-lead TSSOP: θJA = 67.7°C/W, 32-lead LFCSP: θJA = 32.7°C/W; heat sink soldered down to ground plane.
ESD CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although this product features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality. Rev. B | Page 6 of 36 Document Outline Specifications Absolute Maximum Ratings1 Explanation of Test Levels ESD Caution Pin Configurations and Function Descriptions Equivalent Circuits Definitions of Specifications Aperture Delay Aperture Jitter Clock Pulse Width and Duty Cycle Differential Nonlinearity (DNL, No Missing Codes) Effective Number of Bits (ENOB) Gain Error Integral Nonlinearity (INL) Maximum Conversion Rate Minimum Conversion Rate Offset Error Out-of-Range Recovery Time Output Propagation Delay Power Supply Rejection Signal-to-Noise and Distortion (SINAD) Ratio Signal-to-Noise Ratio (SNR) Spurious-Free Dynamic Range (SFDR) Temperature Drift Total Harmonic Distortion (THD) Two-Tone SFDR Typical Performance Characteristics Applying the AD9215 Theory of Operation Analog Input and Reference Overview Differential Input Configurations Single-Ended Input Configuration Clock Input and Considerations Power Dissipation and Standby Mode Digital Outputs Timing Voltage Reference Internal Reference Connection External Reference Operation Operational Mode Selection Evaluation Board Outline Dimensions Ordering Guide
