Datasheet AD9430 (Analog Devices) - 4
Description12-Bit, 170/210 MSPS 3.3 V A/D Converter
Pages / Page45 / 4 — AD9430. REVISION HISTORY. 9/10—Rev. D to Rev. E. 3/03—Rev. 0 to Rev. A. …
RevisionE
AD9430. REVISION HISTORY. 9/10—Rev. D to Rev. E. 3/03—Rev. 0 to Rev. A. 8/05—Rev. C to Rev. D. 11/04—Rev. B to Rev. C
AD9430 REVISION HISTORY 9/10—Rev D to Rev E 3/03—Rev 0 to Rev A 8/05—Rev C to Rev D 11/04—Rev B to Rev C
AD9430 REVISION HISTORY 9/10—Rev. D to Rev. E
Add New AD9430 EVALUATION BOARD, LVDS MODE Change to General Description Section...1 Section ... 27 Change to Operating Temperature Range Parameter, Table 5..10 Updated OUTLINE DIMENSIONS ... 32 Change to Figure 4 ..11
Change to Figure 5 ..13 Upgraded for AD9430-210 .. Universal Added Exposed Pad Notation to Outline Dimensions ..42 Changes to FEATURES ... 1
Changes to PRODUCT HIGHLIGHTS .. 1 Change to I Changes to SPECIFICATIONS ... 2 VREF Spec Units ...4 Changes to Minimum ENOB Specification...6 Changes to Figure 2 .. 5 Added Footnote for Pin 33 in LVDS Mode ...7 Changes to ORDERING GUIDE .. 6 Change to LVDS Output Section ..27 Change to PIN FUNCTION DESCRIPTIONS .. 7 Added New Evaluation Board, CMOS Mode Section..32 Edits to Output Propagation Delay section. .. 10 Updated Outline Dimensions..42 Added TPCs 5–8, 10–12, 14, 16, 18, 20, 22, 27, 31–32, 34 .. 12 Changes to TPCs... 17, 19, 26, 35–36, 38
Added text to ENCODE INPUT section ... 18 Changes to Specifications ..4 Added DS INPUTS section ..19 Changes to Figure 60 .. 31 Change to Table I ..19 Changes to LVDS PCB BOM ... 35 Changes to LVDS Outputs section.. 20 Changes to Figure 68 (Evaluation Board—LVDS Mode) ... 36 Changes to Voltage Reference section ...20 Updated Outline Dimensions .. 40 Replaced Figure 12... 20 Change to Troubleshooting section ...22
7/03—Rev. A to Rev. B
Updated OUTLINE DIMENSIONS...27 Changed order of Figure 1 and Figure 2 .. 5 Updated TPC 13 ...14
5/02—Revision 0: Initial Version
Changes to LVDS OUTPUTS section..20 Rev. E | Page 3 of 44 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION APPLICATIONS TABLE OF CONTENTS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS EXPLANATION OF TEST LEVELS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY APPLICATION NOTES THEORY OF OPERATION ENCODE INPUT ANALOG INPUT DS INPUTS (DS+, DS–) CMOS OUTPUTS LVDS OUTPUTS VOLTAGE REFERENCE NOISE POWER RATIO TESTING (NPR) EVALUATION BOARD, CMOS MODE POWER CONNECTOR ANALOG INPUTS GAIN ENCODE VOLTAGE REFERENCE DATA FORMAT SELECT I/P TIMING SELECT TIMING CONTROLS CMOS DATA OUTPUTS CRYSTAL OSCILLATOR OPTIONAL AMPLIFIER TROUBLESHOOTING EVALUATION BOARD, LVDS MODE POWER CONNECTOR ANALOG INPUTS GAIN CLOCK VOLTAGE REFERENCE DATA FORMAT SELECT DATA OUTPUTS CRYSTAL OSCILLATOR OUTLINE DIMENSIONS ORDERING GUIDE
