Datasheet AD9410 (Analog Devices) - 6
Description10-Bit, 210 MSPS ADC
Pages / Page21 / 6 — AD9410. AC SPECIFICATIONS. Table 4. Parameter. Temp. Test Level. Min. …
File Format / SizePDF / 389 Kb
AD9410. AC SPECIFICATIONS. Table 4. Parameter. Temp. Test Level. Min. Typ. Max. Unit
AD9410 AC SPECIFICATIONS Table 4 Parameter Temp Test Level Min Typ Max Unit
link to page 6
VDD = 3.3 V, VD = 3.3 V, VCC = 5.0 V; 2.5 V external reference; AIN = −0.5 dBFS; clock input = 210 MSPS; TA = 25°C; unless otherwise noted.
Table 4. Parameter Temp Test Level Min Typ Max Unit
DYNAMIC PERFORMANCE Transient Response 25°C V 2 ns Overvoltage Recovery Time 25°C V 2 ns Signal-to-Noise Ratio, SNR (Without Harmonics) fIN = 10.3 MHz 25°C I 52.5 55 dB fIN = 82 MHz 25°C I 52 54 dB fIN = 160 MHz 25°C V 53 dB Signal-to-Noise Ratio, SINAD (With Harmonics) fIN = 10.3 MHz 25°C I 51 54 dB fIN = 82 MHz 25°C I 50 53 dB fIN = 160 MHz 25°C V 52 dB Effective Number of Bits, ENOB fIN = 10.3 MHz 25°C I 8.3 8.8 Bits fIN = 82 MHz 25°C I 8.1 8.6 Bits fIN = 160 MHz 25°C V 8.4 Bits Second Harmonic Distortion fIN = 10.3 MHz 25°C I −56 −65 dBc fIN = 82 MHz 25°C I −55 −63 dBc fIN = 160 MHz 25°C V −65 dBc Third Harmonic Distortion fIN = 10.3 MHz 25°C I −58 −69 dBc fIN = 82 MHz 25°C I −57 −67 dBc fIN = 160 MHz 25°C V −62 dBc Spurious-Free Dynamic Range, SFDR fIN = 10.3 MHz 25°C I 56 61 dBc fIN = 82 MHz 25°C I 54 60 dBc fIN = 160 MHz 25°C V 58 dBc Two-Tone Intermod Distortion, IMD1 fIN1 = 80.3 MHz, fIN2 = 81.3 MHz 25°C V 58 dBFS 1 IN1, IN2 level = −7 dBFS. Rev. A | Page 5 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS SWITCHING SPECIFICATIONS DIGITAL SPECIFICATIONS AC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS EXPLAINATION OF TEST LEVELS Test Level ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION USING THE AD9410 Clock Input ANALOG INPUT DIGITAL OUTPUTS CLOCK OUTPUTS (DCO, ) VOLTAGE REFERENCE TIMING DATA SYNC (DS) OUTLINE DIMENSIONS ORDERING GUIDE
