Datasheet AD7861 (Analog Devices) - 5
Description | 11-Bit Resolution Simultaneous Sampling ADC |
Pages / Page | 7 / 5 — AD7861. PIN DESCRIPTION. PIN CONFIGURATION. Pin. Mnemonic Type. … |
Revision | B |
File Format / Size | PDF / 126 Kb |
AD7861. PIN DESCRIPTION. PIN CONFIGURATION. Pin. Mnemonic Type. Description. REFOUT. AGND. REFIN. AUX0. AUX1. AUX2. AUX3. VIN3. VIN2. 44 43 42. 41 40
AD7861 PIN DESCRIPTION PIN CONFIGURATION Pin Mnemonic Type Description
1 AUX0 I/P Auxiliary Input 0 2 REFIN I/P Analog Reference Input
S1 S0 REFOUT AGND REFIN AUX0 AUX1 AUX2 AUX3 VIN3 VIN2
3 AGND GND Analog Ground
6 5 4 3 2 1 44 43 42 41 40
4 REFOUT O/P Internal 2.5 Analog Reference
D0 7 PIN 1 39 NC IDENTIFIER
5 S0 I/P Aux Channel Select 0
D1 8 38 NC
6 S1 I/P Aux Channel Select 1
D2 9 37 VIN1
7 D0 O/P Data Bit 0 LSB (Tied Low)
D3 10 36 VDD
8 D1 O/P Data Bit 1
D4 11 35 AD7861 SGND
9 D2 O/P Data Bit 2
D5 12 TOP VIEW 34 DGND
10 D3 O/P Data Bit 3
(Not to Scale) D6 13 33 DGND
11 D4 O/P Data Bit 4
D7 14 32 CLK
12 D5 O/P Data Bit 5
D8 15 31 BUSY
13 D6 O/P Data Bit 6
D9 16 30 NC
14 D7 O/P Data Bit 7
D10 17 29 A0
15 D8 O/P Data Bit 8
18 19 20 21 22 23 24 25 26 27 28
16 D9 O/P Data Bit 9
DD M0 M1 CS RD A1
17 D10 O/P Data Bit 10
D11 V NC = NO CONNECT DGND DGND RESET
18 D11 O/P Data Bit 11, MSB
CONVST
19 DGND GND Logic Ground 20 DGND GND Logic Ground 21 VDD SUP +5 V Digital Supply 22 M0 I/P Conversion Mode Select 0 23 M1 I/P Conversion Mode Select 1
Pin Types Pin Types
24 CONVST I/P A/D Conversion Start 25 CS I/P Chip Select I/P = Input Pin GND = Ground Pin O/P = Output Pin SUP = Supply Pin 26 RD I/P Read Input 27 RESET I/P Chip Reset 28 A1 I/P Register Address Select 1 29 A0 I/P Register Address Select 0 30 NC NC No Connect 31 BUSY O/P Busy, Conversion in Process 32 CLK I/P External Clock Input 6.25 MHz-12.5 MHz 33–34 DGND GND Logic Ground 35 SGND GND Signal Ground 36 VDD SUP +5 V Analog Supply 37 VIN1 I/P Analog Input 1 38–39 NC NC No Connect 40 VIN2 I/P Analog Input 2 41 VIN3 I/P Analog Input 3 42 AUX3 I/P Auxiliary Input 3 43 AUX2 I/P Auxiliary Input 2 44 AUX1 I/P Auxiliary Input 1 –4– REV. B
