Datasheet AD7711 (Analog Devices) - 6
DescriptionCMOS, 24-Bit Sigma-Delta, Signal Conditioning ADC with Matched RTD Excitation Currents
Pages / Page29 / 6 — AD7711. (DV. TIMING CHARACTERISTICS1, 2 DD = +5 V. 5%; AVDD = +5 V or +10 …
RevisionG
File Format / SizePDF / 358 Kb
AD7711. (DV. TIMING CHARACTERISTICS1, 2 DD = +5 V. 5%; AVDD = +5 V or +10 V3. 5%; VSS = 0 V or –5 V. 10%; AGND = DGND =
AD7711 (DV TIMING CHARACTERISTICS1, 2 DD = +5 V 5%; AVDD = +5 V or +10 V3 5%; VSS = 0 V or –5 V 10%; AGND = DGND =
10%; AGND = DGND = 0 V; fCLK IN = 10 MHz; Input Logic 0 = 0 V, Logic 1 = DVDD, unless otherwise noted.) Limit at TMIN, TMAX Parameter (A, S Versions) Unit Conditions/Comments
f 4, 5 CLK IN 400 kHz min Master Clock Frequency: Crystal Oscillator or Externally Supplied for Specified Performance 10 MHz max
2
tCLK IN LO 0.4 × tCLK IN ns min Master Clock Input Low Time; tCLK IN = 1/fCLK IN tCLK IN HI 0.4 × tCLK IN ns min Master Clock Input High Time t 6 r 50 ns max Digital Output Rise Time. Typically 20 ns t 6 f 50 ns max Digital Output Fall Time. Typically 20 ns t1 1000 ns min SYNC Pulse Width Self-Clocking Mode t2 0 ns min DRDY to RFS Setup Time t3 0 ns min DRDY to RFS Hold Time t4 2 × tCLK IN ns min A0 to RFS Setup Time t5 0 ns min A0 to RFS Hold Time t6 4 × tCLK IN + 20 ns max RFS Low to SCLK Falling Edge t 7 7 4 × tCLK IN + 20 ns max Data Access Time (RFS Low to Data Valid) t 7 8 tCLK IN/2 ns min SCLK Falling Edge to Data Valid Delay tCLK IN/2 + 30 ns max t9 tCLK IN/2 ns nom SCLK High Pulse Width t10 3 × tCLK IN/2 ns nom SCLK Low Pulse Width t14 50 ns min A0 to TFS Setup Time t15 0 ns min A0 to TFS Hold Time t16 4 × tCLK IN + 20 ns max TFS to SCLK Falling Edge Delay Time t17 4 × tCLK IN ns min TFS to SCLK Falling Edge Hold Time t18 0 ns min Data Valid to SCLK Setup Time t19 10 ns min Data Valid to SCLK Hold Time NOTES 1Guaranteed by design, not production tested. All input signals are specified with tr = tf = 5 ns (10% to 90% of 5 V) and timed from a voltage level of 1.6 V. 2See Figures 10 to 13. 3The AD7711 is specified with a 10 MHz clock for AVDD voltages of 5 V ± 5%. It is specified with an 8 MHz clock for AVDD voltages greater than 5.25 V and less than 10.5 V. 4CLK IN duty cycle range is 45% to 55%. CLK IN must be supplied whenever the AD7711 is not in STANDBY mode. If no clock is present in this case, the device can draw higher current than specified and possibly become uncalibrated. 5The AD7711 is production tested with fCLK IN at 10 MHz (8 MHz for AVDD > 5.25 V). It is guaranteed by characterization to operate at 400 kHz. 6Specified using 10% and 90% points on waveform of interest. 7These numbers are measured with the load circuit of Figure 1 and defined as the time required for the output to cross 0.8 V or 2.4 V. REV.G –5– Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS SPECIFICATIONS TIMING CHARACTERISTICS PIN FUNCTION DESCRIPTIONS TERMINOLOGY Intergral Nonlinearity Positive Full-Scale Error Unipolar Offset Error Bipolar Zero Error Bipolar Negative Full-Scale Error Positive Full-Scale Overrange Negative Full-Scale Overrange Offset Calibration Range Full-Scale Calibration Range Input Span CONTROL REGISTER (24 BITS) FILTER SELECTION (FS11–FS0) CIRCUIT DESCRIPTION THEORY OF OPERATION Input Sample Rate DIGITAL FILTERING Filter Characteristics Post Filtering Antialias Considerations ANALOG INPUT FUNCTIONS Analog Input Ranges Burnout Current RTD Excitation Current Bipolar/Unipolar Inputs REFERENCE INPUT/OUTPUT VBIAS Input USING THE AD7711 SYSTEM DESIGN CONSIDERATIONS Clocking System Synchronization Accuracy Autocalibration Self-Calibration System Calibration System Offset Calibration Background Calibration Span and Offset Limits POWER-UP AND CALIBRATION Drift Considerations POWER SUPPLIES AND GROUNDING DIGITAL INTERFACE Self-Clocking Mode Read Operation Write Operation External Clocking Mode Read Operation Write Operation SIMPLIFYING THE EXTERNAL CLOCKING MODE INTERFACE MICROCOMPUTER/MICROPROCESSOR INTERFACING AD7711 to 8051 Interface AD7711 to 68HC11 Interface APPLICATIONS 4-Wire RTD Configurations 3-Wire RTD Configurations OUTLINE DIMENSIONS Revision History
