Datasheet ADL5562 (Analog Devices) - 5
Description | 3.3 GHz Ultralow Distortion RF/IF Differential Amplifier |
Pages / Page | 21 / 5 — Data Sheet. ADL5562. Parameter. Conditions. Min Typ. Max Unit |
Revision | F |
File Format / Size | PDF / 566 Kb |
link to page 14
Data Sheet ADL5562 Parameter Conditions Min Typ Max Unit
250 MHz NOISE/HARMONIC PERFORMANCE Second/Third Harmonic Distortion AV = 6 dB, RL = 200 Ω, VOUT = 2 V p-p −80/−94 dBc AV = 12 dB, RL = 200 Ω, VOUT = 2 V p-p −74/−86 dBc AV = 15.5 dB, RL = 200 Ω, VOUT = 2 V p-p −74/−84 dBc Output Third-Order Intercept/Third-Order AV = 6 dB, RL = 200 Ω, VOUT = 2 V p-p composite +43/−94 dBm/dBc Intermodulation Distortion (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = 2 V p-p composite +41/−87 dBm/dBc (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = 2 V p-p composite +40/−86 dBm/dBc (2 MHz spacing) Noise Spectral Density (RTI) AV = 6 dB 3.2 nV/√Hz AV = 12 dB 2.2 nV/√Hz AV = 15.5 dB 1.6 nV/√Hz 1 dB Compression Point (RTO) AV = 6 dB 13 dBm AV = 12 dB 13 dBm AV = 15.5 dB 12 dBm 500 MHz NOISE/HARMONIC PERFORMANCE Second/Third Harmonic Distortion AV = 6 dB, RL = 200 Ω, VOUT = 1 V p-p −75/−69 dBc AV = 12 dB, RL = 200 Ω, VOUT = 1 V p-p −69/−73 dBc AV = 15.5 dB, RL = 200 Ω, VOUT = 1 V p-p −72/−75 dBc Output Third-Order Intercept/Third-Order AV = 6 dB, RL = 200 Ω, VOUT = 1 V p-p composite +40/−98 dBm/dBc Intermodulation Distortion (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = 1 V p-p composite +39/−97 dBm/dBc (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = 1 V p-p composite +38/−93 dBm/dBc (2 MHz spacing) Noise Spectral Density (RTI) AV = 6 dB 3.7 nV/√Hz AV = 12 dB 2.2 nV/√Hz AV = 15.5 dB 1.6 nV/√Hz 1000 MHz NOISE/HARMONIC PERFORMANCE Second/Third Harmonic Distortion AV = 6 dB, RL = 200 Ω, VOUT = 1 V p-p −70/−60 dBc AV = 12 dB, RL = 200 Ω, VOUT = 1 V p-p −69/−61 dBc AV = 15.5 dB, RL = 200 Ω, VOUT = 1 V p-p −66/−59 dBc Output Third-Order Intercept/Third-Order AV = 6 dB, RL = 200 Ω, VOUT = 1 V p-p composite +24/−65 dBm/dBc Intermodulation Distortion (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = 1 V p-p composite +24/−66 dBm/dBc (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = 1 V p-p composite +25/−66 dBm/dBc (2 MHz spacing) Noise Spectral Density (RTI) AV = 6 dB 4.7 nV/√Hz AV = 12 dB 2.2 nV/√Hz AV = 15.5 dB 1.6 nV/√Hz 1 See the Applications Information section for a discussion of single-ended input, dc-coupled operation. Rev. F | Page 5 of 21 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION BASIC STRUCTURE APPLICATIONS INFORMATION BASIC CONNECTIONS INPUT AND OUTPUT INTERFACING Single-Ended Input to Differential Output GAIN ADJUSTMENT AND INTERFACING ADC INTERFACING LAYOUT CONSIDERATIONS SOLDERING INFORMATION EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
