Datasheet ADL5561 (Analog Devices) - 4
Description2.9 GHz Ultralow Distortion RF/IF Differential Amplifier
Pages / Page25 / 4 — Data Sheet. ADL5561. SPECIFICATIONS. Table 1. Parameter. Conditions. Min. …
RevisionG
File Format / SizePDF / 773 Kb
Data Sheet. ADL5561. SPECIFICATIONS. Table 1. Parameter. Conditions. Min. Typ. Max. Unit
Data Sheet ADL5561 SPECIFICATIONS Table 1 Parameter Conditions Min Typ Max Unit
link to page 6
VCC = 3.3 V, VCOM = 1.65 V, RL = 200 Ω differential, AV = 6 dB, CL = 1 pF differential, f = 140 MHz, TA = 25°C.
Table 1. Parameter Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE −3 dB Bandwidth AV = 6 dB, VOUT ≤ 1.0 V p-p 2900 MHz AV = 12 dB, VOUT ≤ 1.0 V p-p 2300 MHz AV = 15.5 dB, VOUT ≤ 1.0 V p-p 1800 MHz Bandwidth for 0.1 dB Flatness AV = 6 dB, VOUT ≤ 1.0 V p-p 200 MHz AV = 12 dB, VOUT ≤ 1.0 V p-p 200 MHz AV = 15.5 dB, VOUT ≤ 1.0 V p-p 600 MHz Gain Accuracy AV = 6 dB, RL = open 0.15 dB AV = 12 dB, RL = open 0.05 dB AV = 15.5 dB, RL = open 0.05 dB Gain Supply Sensitivity VCC ± 10% −0.023 dB/V Gain Temperature Sensitivity −40°C to +85°C, AV =15.5 dB 0.24 mdB/°C Slew Rate Rise, AV = 15.5 dB, RL= 200 Ω, VOUT = 2 V step 9.8 V/ns Fall, AV = 15.5 dB, RL = 200 Ω, VOUT = 2 V step 10.1 V/ns Settling Time 2 V step to 1% 2 ns Overdrive Recovery Time VIN = 4 V to 0 V step, VOUT ≤ ±10 mV 3 ns Reverse Isolation (S12) 60 dB INPUT/OUTPUT CHARACTERISTICS Output Common Mode VCC/2 V Voltage Adjustment Range 1.4 to 1.8 V Maximum Output Voltage Swing 1 dB compressed 4.3 V p-p Output Common-Mode Offset Referenced to VCC/2 25 mV Output Common-Mode Drift −40°C to +85°C 170 µV/°C Output Differential Offset Voltage 1 mV CMRR 65 dB Output Differential Offset Drift −40°C to +85°C 15 µV/°C Input Bias Current 3 µA Input Resistance (Differential) AV = 6 dB 400 Ω AV = 12 dB 200 Ω AV = 15.5 dB 133 Ω Input Resistance (Single-Ended)1 AV = 5.6 dB, RS = 50 Ω 307 Ω AV = 11.1 dB, RS = 50 Ω 179 Ω AV = 14.1 dB, RS = 50 Ω 132 Ω Input Resistance Tolerance −10 +10 % Input Capacitance (Single-Ended) 0.3 pF Output Resistance (Differential) 12 Ω POWER INTERFACE Supply Voltage 3 3.3 3.6 V ENBL Threshold Device disabled, ENBL low 0.5 V Device enabled, ENBL high 1.5 V ENBL Input Bias Current ENBL high −27 µA ENBL low −300 µA Quiescent Current ENBL high 37 40 44.5 mA ENBL low 3 mA Rev. G | Page 3 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION BASIC STRUCTURE APPLICATIONS INFORMATION BASIC CONNECTIONS INPUT AND OUTPUT INTERFACING Single-Ended Input to Differential Output GAIN ADJUSTMENT AND INTERFACING ADC INTERFACING LAYOUT CONSIDERATIONS SOLDERING INFORMATION EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
