Datasheet ADL5561 (Analog Devices) - 5
Description | 2.9 GHz Ultralow Distortion RF/IF Differential Amplifier |
Pages / Page | 25 / 5 — ADL5561. Data Sheet. Parameter. Conditions. Min. Typ. Max. Unit |
Revision | G |
File Format / Size | PDF / 773 Kb |
ADL5561 Data Sheet Parameter Conditions Min Typ Max Unit
10 MHz NOISE/HARMONIC PERFORMANCE Second/Third Harmonic Distortion AV = 6 dB, RL = 200 Ω, VOUT = 2 V p-p −94/−87 dBc AV = 12 dB, RL = 200 Ω, VOUT = 2 V p-p −92/−88 dBc AV = 15.5 dB, RL = 200 Ω, VOUT = 2 V p-p −95/−87 dBc Output Third-Order Intercept/Third-Order AV= 6 dB, RL = 200 Ω, VOUT = 2 V p-p +42.7/−89 dBm/dBc Intermodulation Distortion composite (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = 2 V p-p +41/−85 dBm/dBc composite (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = 2 V p-p +40/−85 dBm/dBc composite (2 MHz spacing) Noise Spectral Density (RTI) AV = 6 dB 3 nV/√Hz AV = 12 dB 2.1 nV/√Hz AV = 15.5 dB 1.7 nV/√Hz 1 dB Compression Point (RTO) AV = 6 dB 12.5 dBm AV = 12 dB 12.5 dBm AV = 15.5 dB 12.5 dBm 70 MHz NOISE/HARMONIC PERFORMANCE Second/Third Harmonic Distortion AV = 6 dB, RL = 200 Ω, VOUT = 2 V p-p −98/−87 dBc AV = 12 dB, RL = 200 Ω, VOUT = 2 V p-p −93/−83 dBc AV = 15.5 dB, RL = 200 Ω, VOUT = 2 V p-p −93/−82 dBc Output Third-Order Intercept/Third-Order AV = 6 dB, RL = 200 Ω, VOUT = 2 V p-p +45/−93 dBm/dBc Intermodulation Distortion composite (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = 2 V p-p +43/−89 dBm/dBc composite (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = 2 V p-p +41/−86 dBm/dBc composite (2 MHz spacing) Noise Spectral Density (RTI) AV = 6 dB 3 nV/√Hz AV = 12 dB 2.1 nV/√Hz AV = 15.5 dB 1.7 nV/√Hz 1 dB Compression Point (RTO) AV = 6 dB 12.3 dBm AV = 12 dB 12.3 dBm AV = 15.5 dB 12.3 dBm 140 MHz NOISE/HARMONIC PERFORMANCE Second/Third Harmonic Distortion AV = 6 dB, RL = 200 Ω, VOUT = 2 V p-p −95/−87 dBc AV = 12 dB, RL = 200 Ω, VOUT = 2 V p-p −83/−83 dBc AV = 15.5 dB, RL = 200 Ω, VOUT = 2 V p-p −83/−82 dBc Output Third-Order Intercept/Third-Order AV = 6 dB, RL = 200 Ω, VOUT = 2 V p-p +49/−102 dBm/dBc Intermodulation Distortion composite (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = 2 V p-p +48/−100 dBm/dBc composite (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = 2 V p-p +39/−96 dBm/dBc composite (2 MHz spacing) Noise Spectral Density (RTI) AV = 6 dB 3 nV/√Hz AV = 12 dB 2.1 nV/√Hz AV = 15.5 dB 1.7 nV/√Hz 1 dB Compression Point (RTO) AV = 6 dB 12 dBm AV = 12 dB 12 dBm AV = 15.5 dB 12 dBm Rev. G | Page 4 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION BASIC STRUCTURE APPLICATIONS INFORMATION BASIC CONNECTIONS INPUT AND OUTPUT INTERFACING Single-Ended Input to Differential Output GAIN ADJUSTMENT AND INTERFACING ADC INTERFACING LAYOUT CONSIDERATIONS SOLDERING INFORMATION EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
