Datasheet ADL5561 (Analog Devices) - 9
Description2.9 GHz Ultralow Distortion RF/IF Differential Amplifier
Pages / Page25 / 9 — ADL5561. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. –40°C. MAXIMUM …
RevisionG
File Format / SizePDF / 773 Kb
ADL5561. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. –40°C. MAXIMUM GAIN. +25°C. +85°C. 12 MID GAIN. dB). dBm). N (. B (. AI G. P1d
ADL5561 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS –40°C MAXIMUM GAIN +25°C +85°C 12 MID GAIN dB) dBm) N ( B ( AI G P1d
VCC = 3.3 V, VCOM = 1.65 V, RL = 200 Ω differential, AV = 6 dB, CL = 1 pF differential, f = 140 MHz, and TA = 25°C.
16 14 –40°C MAXIMUM GAIN +25°C +85°C 14 12 10 12 MID GAIN dB) dBm) 8 10 N ( B ( AI G P1d 6 O MAX GAIN –40°C 8 MAX GAIN +25°C 4 MAX GAIN +85°C MID GAIN –40°C MID GAIN +25°C 6 MINIMUM GAIN 2 MID GAIN +85°C MIN GAIN –40°C MIN GAIN +25°C MIN GAIN +85°C 4 0 10M 100M 1G 10G
002
0 50 100 150 200 250
016
FREQUENCY (Hz) FREQUENCY (MHz)
08004- 08004- Figure 3. Gain vs. Frequency Response for 200 Ω Differential Load, Figure 6. Output P1dB (OP1dB) vs. Frequency at AV = 6 dB, AV = 12 dB, and AV = 6 dB, AV = 12 dB, and AV = 15.5 dB over Temperature AV = 15.5 dB over Temperature, 200 Ω Differential Load
16 14 –40°C MAX GAIN –40°C MAXIMUM GAIN +25°C MAX GAIN +25°C +85°C MAX GAIN +85°C 14 12 MID GAIN –40°C MID GAIN +25°C MID GAIN +85°C 10 MIN GAIN –40°C 12 MIN GAIN +25°C MID GAIN MIN GAIN +85°C dB) 8 dBm) N ( 10 B ( AI G 6 P1d O 8 4 6 MINIMUM GAIN 2 4 0 10M 100M 1G 10G
003
017
FREQUENCY (Hz)
08004-
FREQUENCY (MHz)
08004- Figure 4. Gain vs. Frequency Response for 1 kΩ Differential Load Figure 7. Output P1dB (OP1dB) vs. Frequency at AV = 6 dB, AV = 12 dB, and AV = 6 dB, AV = 12 dB, and AV = 15.5 dB over Temperature AV = 15.5 dB over Temperature, 1 kΩ Differential Load
16 8 A A V MAXIMUM V MAXIMUM A A 14 V MID V MID A ) 7 A V MINIMUM V MINIMUM √Hz 12 V/ 6 ) Y (n 10 IT 5 E (dB R NS 8 4 L DE A E FIGU TR OIS 6 3 N 4 2 ISE SPEC O 2 N 1 0 0 10 100 1000
004 015
10 100 1000 FREQUENCY (MHz)
08004-
FREQUENCY (MHz)
08004- Figure 5. Noise Figure vs. Frequency at Figure 8. Noise Spectral Density vs. Frequency at AV = 6 dB, AV = 12 dB, and AV = 15.5 dB AV = 6 dB, AV = 12 dB, and AV = 15.5 dB Rev. G | Page 8 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION BASIC STRUCTURE APPLICATIONS INFORMATION BASIC CONNECTIONS INPUT AND OUTPUT INTERFACING Single-Ended Input to Differential Output GAIN ADJUSTMENT AND INTERFACING ADC INTERFACING LAYOUT CONSIDERATIONS SOLDERING INFORMATION EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
