Datasheet ADL5904 (Analog Devices) - 3
DescriptionDC to 6 GHz, 45 dB TruPwr Detector with Envelope Threshold Detection
Pages / Page27 / 3 — Data Sheet. ADL5904. SPECIFICATIONS. Table 1. Parameter. Test …
Data Sheet. ADL5904. SPECIFICATIONS. Table 1. Parameter. Test Conditions/Comments. Min Typ. Max. Unit
Data Sheet ADL5904 SPECIFICATIONS Table 1 Parameter Test Conditions/Comments Min Typ Max Unit
VPOS = 3.3 V, continuous wave (CW) input, TA = 25°C, ZO = 50 Ω, Capacitor CRMS = 10 nF, unless otherwise noted.
Table 1. Parameter Test Conditions/Comments Min Typ Max Unit
OVERALL FUNCTION Frequency Range dc to 6000 MHz f = 10 MHz ±1.0 dB Input Range 45 dB Input Level, ±1.0 dB Maximum Three-point calibration at −25 dBm, −10 dBm, and +10 dBm 15 dBm Minimum −30 dBm VRMS Output Voltage RFIN pin = 10 dBm 1.63 V RFIN pin = −20 dBm 0.54 V VRMS Deviation vs. Temperature Deviation from output at 25°C −40°C < TA < +85°C, PIN = 10 dBm −0.1/+0.2 dB −40°C < TA < +105°C, PIN = 10 dBm −0.1/+0.2 dB −40°C < TA < +85°C, PIN = −15 dBm −0.2/+0.2 dB −40°C < TA < +105°C, PIN = −15 dBm −0.4/+0.2 dB VRMS Logarithmic Slope PIN = −25 dBm to −10 dBm 36.5 mV/dB PIN = −10 dBm to +10 dBm 35.3 mV/dB VRMS Logarithmic Intercept PIN = −25 dBm to −10 dBm −35.2 dBm PIN = −0 dBm to +10 dBm −36 dBm VIN− Setpoint Voltage For threshold detection at 10 dBm 743 mV For threshold detection at 0 dBm 240 mV For threshold detection at −10 dBm 80 mV Threshold Variation vs. −40°C < TA < +85°C, PIN ≈ 10 dBm ±0.2 dB Temperature −40°C < TA < +85°C, PIN ≈ 0 dBm −0.3/0 dB −40°C < TA < +85°C, PIN ≈ −10 dBm −0.5/0 dB −40°C < TA < +105°C, PIN ≈ 10 dBm ±0.2 dB −40°C < TA < +105°C, PIN ≈ 0 dBm −0.3/0 dB −40°C < TA < +105°C, PIN ≈ −10 dBm −0.5/0 dB f = 30 MHz ±1.0 dB Input Range 45 dB Input Level, ±1.0 dB Maximum Three-point calibration at −25 dBm, −10 dBm, and +10 dBm 15 dBm Minimum −30 dBm VRMS Output Voltage RFIN pin = 10 dBm 1.62 V RFIN pin = −20 dBm 0.54 V VRMS Deviation vs. Temperature Deviation from output at 25°C −40°C < TA < +85°C, PIN = 10 dBm −0.1/+0.1 dB −40°C < TA < +105°C, PIN = 10 dBm −0.1/+0.1 dB −40°C < TA < +85°C, PIN = −15 dBm −0.2/+0.2 dB −40°C < TA < +105°C, PIN = −15 dBm −0.5/+0.2 dB VRMS Logarithmic Slope PIN = −25 dBm to −10 dBm 36.8 mV/dB PIN = −10 dBm to +10 dBm 35.4 mV/dB VRMS Logarithmic Intercept PIN = −25 dBm to −10 dBm −34.7 dBm PIN = −10 dBm to +10 dBm −35.7 dBm VIN− Setpoint Voltage For threshold detection at 10 dBm 723 V For threshold detection at 0 dBm 238 mV For threshold detection at −10 dBm 80 mV Rev. B | Page 3 of 27 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION BASIC CONNECTIONS FOR RMS MEASUREMENT CHOOSING A VALUE FOR CRMS VRMS CALIBRATION AND ERROR CALCULATION BASIC CONNECTIONS FOR THRESHOLD DETECTION Q AND QB RESPONSE TIME SETTING THE VIN− THRESHOLD DETECTION VOLTAGE APPLICATIONS INFORMATION EVALUATION BOARD SCHEMATIC AND CONFIGURATION OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
