Datasheet ADL5904 (Analog Devices) - 10
DescriptionDC to 6 GHz, 45 dB TruPwr Detector with Envelope Threshold Detection
Pages / Page27 / 10 — ADL5904. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 2.0. 1.8. 10MHz …
ADL5904. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 2.0. 1.8. 10MHz 30MHz. 100MHz. 1.6. PIN = +10dBm. 900MHz. 1900MHz. 1.4. 2600MHz
ADL5904 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 2.0 1.8 10MHz 30MHz 100MHz 1.6 PIN = +10dBm 900MHz 1900MHz 1.4 2600MHz
VPOS = 3.3 V, CRMS = 10 nF, Input levels referred to 50 Ω source. Input RF signal is a sine wave (CW), unless otherwise indicated.
2.0 1.8 10MHz 30MHz 1.8 100MHz 1.6 PIN = +10dBm 900MHz 1.6 1900MHz 1.4 2600MHz 1.4 3500MHz P 5800MHz IN = 0dBm 1.2 1.2 (V) 1.0 (V) S 1.0 S PIN = –10dBm RM RM V 0.8 V 0.8 0.6 P 0.6 IN = –20dBm 0.4 0.4 PIN = –30dBm 0.2 0.2 0 0 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 15 20
003
0 1 2 3 4 5 6
006
PIN (dBm)
13838-
FREQUENCY (GHz)
13838- Figure 3. VRMS vs. Input Level (PIN) for Various Frequencies Figure 6. VRMS vs. Frequency for Four Input Levels (10 MHz to 6 GHz) (30 MHz to 6 GHz) at 25°C
2.4 6 2.4 6 CW CW 2.2 16 QAM PEP = 6.38dB 5 2.2 16 QAM PEP = 6.38dB 5 64 QAM PEP = 7.03dB 64 QAM PEP = 7.03dB 2.0 QPSK PEP = 4.02dB 4 2.0 QPSK PEP = 4.02dB 4 1.8 3 1.8 3 1.6 2 1.6 2 1.4 1 B) B) d 1.4 1 d (V) (V) S 1.2 0 R ( S 1.2 0 R ( RM RM V 1.0 –1 RRO V 1.0 –1 RRO E E 0.8 –2 –2 0.8 0.6 –3 –3 0.6 0.4 –4 –4 0.4 0.2 –5 –5 0.2 CALIBRATION AT –20dBm, 0dBm, AND +10dBm CALIBRATION AT –20dBm, 0dBm, AND +10dBm 0 –6 –6 0 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 15
004
007
PIN (dBm) P
13838-
IN (dBm)
13838- Figure 4. VRMS and Error from CW Linear Reference vs. Input Level and Signal Figure 7. VRMS and Error from CW Linear Reference vs. Input Level and Signal Modulation (QPSK, 16 QAM, 64 QAM), Frequency = 900 MHz, Modulation (QPSK, 16 QAM, 64 QAM), Frequency = 2.14 GHz, CRMS = 1 µF CRMS = 1 µF (PEP Is Peak Envelope Power)
2.4 6 2.4 6 CW CW 2.2 4 CARRIER CDMA PEP = 12.03dB 5 2.2 LTE TM1 1-CARRIER 20MHz PEP = 11.58dB 5 1 CARRIER CDMA PEP = 10.56dB 2.0 4 2.0 4 1.8 3 1.8 3 1.6 2 1.6 2 B) d 1.4 1 B) d 1.4 1 R ( (V) (V) S 1.2 0 R ( S 1.2 0 RRO RM RM V E 1.0 –1 RRO V E 1.0 –1 0.8 –2 0.8 –2 0.6 –3 0.6 –3 0.4 –4 0.4 –4 0.2 –5 0.2 –5 CALIBRATION AT –20dBm, 0dBm, AND +10dBm CALIBRATION AT –20 dBm, 0 dBm, AND +10dBm 0 –6 0 –6 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 15
005
008
PIN (dBm)
13838-
PIN (dBm)
13838- Figure 5. VRMS and Error from CW Linear Reference vs. Input Level and Signal Figure 8. VRMS and Error from CW Linear Reference vs. Input Level and Signal Modulation (One-Carrier W-CDMA, Four-Carrier W-CDMA), Modulation (LTE TM1 One-Carrier, 20 MHz), Frequency = 2.14 GHz, CRMS = 1 µF Frequency = 2.14 GHz, CRMS = 1 µF Rev. B | Page 10 of 27 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION BASIC CONNECTIONS FOR RMS MEASUREMENT CHOOSING A VALUE FOR CRMS VRMS CALIBRATION AND ERROR CALCULATION BASIC CONNECTIONS FOR THRESHOLD DETECTION Q AND QB RESPONSE TIME SETTING THE VIN− THRESHOLD DETECTION VOLTAGE APPLICATIONS INFORMATION EVALUATION BOARD SCHEMATIC AND CONFIGURATION OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
