Datasheet HMC611LP4, 611LP4E (Analog Devices) - 5
DescriptionLogarithmic Detector Controller SMT, 0.001 - 10.0 GHz
Pages / Page10 / 5 — HMC611LP4 / 611LP4E. 60 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 1 - 10000 …
File Format / SizePDF / 569 Kb
HMC611LP4 / 611LP4E. 60 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 1 - 10000 MHz. LOGOUT Intercept vs. Frequency
HMC611LP4 / 611LP4E 60 dB, LOGARITHMIC DETECTOR / CONTROLLER, 1 - 10000 MHz LOGOUT Intercept vs Frequency
HMC611LP4 / 611LP4E
v04.0309
60 dB, LOGARITHMIC DETECTOR / CONTROLLER, 1 - 10000 MHz LOGOUT Intercept vs. Frequency LOGOUT Intercept vs. Supply Voltage
30 26 24 27 22 24 20 21 18 18 INTERCEPT (dBm) +25C INTERCEPT (dBm) 16 0.1GHz +85C 1.9GHz -40C 3.6GHz 15 14 5.8GHz 12 8GHz 10GHz 12 12 0 2 4 6 8 10 4.5 5 5.5 FREQUENCY (GHz) Vcc1, Vcc2, Vcc3 (V) T
Absolute Maximum Ratings
Vcc1, Vcc2, Vcc3 +5.6V S - SM EN +5.6V ELECTROSTATIC SENSITIVE DEVICE R VSET Input Voltage +5.6V OBSERVE HANDLING PRECAUTIONS O LOGOUT Output Current 3 mA T RF Input Power +15 dBm C Junction Temperature 125 °C E Continuous Pdiss (T = 85°C) T 1.55 Watts (Derate 7.95 mW/°C above 85°C) E Thermal Resistance (R ) th 42 °C/W (junction to lead) Storage Temperature -65 to +150 °C R D E Operating Temperature -40 to +85 °C W O P [1] Unless otherwise noted: Vcc1, Vcc2, Vcc3 = +5V, TA = +25C Information furnis F heod r pri by An ce, de alog Devi lcievs eir s y b , a eliev nd to pla ed to be accu ce o rate anrder d relia sbl, pl e. H ease co owever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone: 978 rights of third parties that may result from its use. Specifications subject to change without notice. No Ph - o 25 ne 0 : 7 -3 81- 3 3 4 29 3 F -470 ax: 978 0 • Orde - r o 25 nlin 0- e a3 t 373
12 - 52
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Order On-l Trademarks and registered trademarks are the property of their respective owners. ine at www.hit A ti p te.co plicati m on Support: Phone: 1-800-ANALOG-D
