Datasheet HMC611LP4, 611LP4E (Analog Devices) - 6
DescriptionLogarithmic Detector Controller SMT, 0.001 - 10.0 GHz
Pages / Page10 / 6 — HMC611LP4 / 611LP4E. 60 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 1 - 10000 …
File Format / SizePDF / 569 Kb
HMC611LP4 / 611LP4E. 60 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 1 - 10000 MHz. Outline Drawing. Package Information. 12 - 53
HMC611LP4 / 611LP4E 60 dB, LOGARITHMIC DETECTOR / CONTROLLER, 1 - 10000 MHz Outline Drawing Package Information 12 - 53
HMC611LP4 / 611LP4E
v04.0309
12 T S - SM R O NOTES: 1. LEADFRAME MATERIAL: COPPER ALLOY T 2. DIMENSIONS ARE IN INCHES [MILLIMETERS]. C 3. LEAD SPACING TOLERANCE IS NON-CUMULATIVE E 4. PAD BURR LENGTH SHALL BE 0.15mm MAXIMUM. T PAD BURR HEIGHT SHALL BE 0.05mm MAXIMUM. 5. PACKAGE WARP SHALL NOT EXCEED 0.05mm. E 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND. 7. REFER TO HMC APPLICATION NOTE FOR SUGGESTED PCB LAND PATTERN. R D E W O
Package Information
P Part Number Package Body Material Lead Finish MSL Rating Package Marking [3] [1] H611 HMC611LP4 Low Stress Injection Molded Plastic Sn/Pb Solder MSL1 XXXX [2] H611 HMC611LP4E RoHS-compliant Low Stress Injection Molded Plastic 100% matte Sn MSL1 XXXX [1] Max peak refl ow temperature of 235 °C [2] Max peak refl ow temperature of 260 °C [3] 4-Digit lot number XXXX Information furnis F heod r pri by An ce, de alog Devi lcievs eir s y b , a eliev nd to pla ed to be accu ce o rate anrder d relia sbl, pl e. H ease co owever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone: 978 rights of third parties that may result from its use. Specifications subject to change without notice. No Ph - o 25 ne 0 : 7 -3 81- 3 3 4 29 3 F -470 ax: 978 0 • Orde - r o 25 nlin 0- e a3 t 373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
12 - 53
Order On-l Trademarks and registered trademarks are the property of their respective owners. ine at www.hit A ti p te.co plicati m on Support: Phone: 1-800-ANALOG-D
