Datasheet ADA4800-KGD (Analog Devices) - 6
DescriptionLow Power, High Speed CCD Buffer Amplifier
Pages / Page7 / 6 — ADA4800-KGD. Known Good Die. TEST CIRCUIT. VISF. 0V TO 3V. GPO PIN. ISF. …
File Format / SizePDF / 206 Kb
ADA4800-KGD. Known Good Die. TEST CIRCUIT. VISF. 0V TO 3V. GPO PIN. ISF. 47µF. IDRV. 0.1µF. 15V. 10kΩ. 249kΩ. VCC. IIDRV. IISF. IBUFF. IAL. VEE. OUT. CCD. AFE
ADA4800-KGD Known Good Die TEST CIRCUIT VISF 0V TO 3V GPO PIN ISF 47µF IDRV 0.1µF 15V 10kΩ 249kΩ VCC IIDRV IISF IBUFF IAL VEE OUT CCD AFE
ADA4800-KGD Known Good Die TEST CIRCUIT VISF 0V TO 3V R + R GPO PIN ISF 47µF IDRV 0.1µF 15V 10kΩ 249kΩ 0.1µF ISF VCC IDRV 0.1µF 6 5 4 IIDRV IISF IBUFF ADA4800-KGD +1 IAL 1 2 3 IN VEE OUT
3
CCD AFE
-00 21 6 15 Figure 3. Typical Current Flow Rev. 0 | Page 6 of 7 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS BUFFER ELECTRICAL CHARACTERISTICS ACTIVE CURRENT LOAD ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TEST CIRCUIT OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
