Datasheet MAX4162, MAX4163, MAX4164 (Maxim) - 7
ManufacturerMaxim
DescriptionUCSP, Micropower, Single-Supply, 10V, Rail-to-Rail I/O Op Amps
Pages / Page13 / 7 — UCSP, Micropower, Single-Supply, 10V,. Rail-to-Rail I/O Op Amps. …
File Format / SizePDF / 331 Kb
UCSP, Micropower, Single-Supply, 10V,. Rail-to-Rail I/O Op Amps. MAX4162/MAX4163/MAX4164
UCSP, Micropower, Single-Supply, 10V, Rail-to-Rail I/O Op Amps MAX4162/MAX4163/MAX4164
UCSP, Micropower, Single-Supply, 10V, Rail-to-Rail I/O Op Amps MAX4162/MAX4163/MAX4164 Typical Operating Characteristics (continued)
(VDD = 5V, VSS = 0V, VCM = VDD/2, TA = +25°C, unless otherwise noted.)
TOTAL HARMONIC DISTORTION PLUS NOISE GAIN AND PHASE vs. FREQUENCY vs. OUTPUT VOLTAGE SWING (CL = 0)
1 60 MAX4162-22 180 A R V = 1 L = 100kΩ 144 MAX4162-21c R C L = 100kΩ L = 0 f = 5kHz 40 AV = 1000 108 GAIN 72 20 36 0.1 0 GAIN (dB) THD + N (%) 0 -36 PHASE (degrees) PHASE -72 -20 -108 f = 1kHz -144 0.01 -40 -180 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 1 100 1k 10k 100k 1M PEAK-TO-PEAK OUTPUT VOLTAGE SWING (V) FREQUENCY (Hz)
GAIN AND PHASE vs. FREQUENCY GAIN AND PHASE vs. FREQUENCY (CL = 500pF) (CL = 0.01
µ
F)
60 MAX4162-23 180 60 MAX4162-24 180 RL = 100kΩ R 144 L = 100kΩ 144 CL = 500pF CL = 0.01µF GAIN 40 AV = 1000 108 40 AV = 1000 108 GAIN 72 72 20 36 20 36 0 0 GAIN (dB) GAIN (dB) 0 -36 0 -36 PHASE (degrees) PHASE (degrees) -72 -72 PHASE -20 -108 -20 -108 PHASE -144 -144 -40 -180 -40 -180 1 100 1k 10k 100k 1M 1 100 1k 10k 100k 1M FREQUENCY (Hz) FREQUENCY (Hz)
NONINVERTING NONINVERTING SMALL-SIGNAL PULSE RESPONSE SMALL-SIGNAL PULSE RESPONSE (VDD = 3V, CL = 0) (VDD = 3V, CL = 1500pF)
MAX4162-25 MAX4162-26 IN IN 50mV/div 50mV/div OUT OUT 50mV/div 50mV/div 100µs/div 100µs/div VDD = 3V, VIN = 100mV, RL = 100kΩ to VDD/2, VDD = 3V, VIN = 100mV, RL = 100kΩ to VDD/2, CL = 0 CL = 1500pF
_______________________________________________________________________________________ 7
