Datasheet LTC4300A-3 (Analog Devices) - 4
DescriptionLevel Shifting Hot Swappable 2-Wire Bus Buffer with Enable
Pages / Page14 / 4 — elecTrical characTerisTics Note 1:. Note 4:. Note 5:. Note 6:. Note 2:. …
File Format / SizePDF / 216 Kb
elecTrical characTerisTics Note 1:. Note 4:. Note 5:. Note 6:. Note 2:. Note 3:. Typical perForMance characTerisTics
elecTrical characTerisTics Note 1: Note 4: Note 5: Note 6: Note 2: Note 3: Typical perForMance characTerisTics
LTC4300A-3
Note 4:
Guaranteed by design, not subject to test. may cause permanent damage to the device. Exposure to any Absolute
Note 5:
CB = total capacitance of one bus line in pF. Maximum Rating condition for extended periods may affect device
Note 6:
These tests measure the difference in high-to-low propagation reliability and lifetime. delay tPHL between the clock and data channels. The delay on each
Note 2:
IPULLUPAC varies with temperature and VCC voltage, as shown in channel is measured from the 50% point of the falling driven input signal the Typical Performance Characteristics section. to the 50% point of the output driven by the LTC4300A-3.The skew is
Note 3:
The connection circuitry always regulates its output to a higher defined as (tPHL(SCL)-tPHL(SDA)). Testing is performed in both directions— voltage than its input. The magnitude of this offset voltage as a function of from input bus to output bus and vice versa. Tests are performed with the pull-up resistor and VCC voltage is shown in the Typical Performance approximately 500pF of distributed equivalent capacitance on each SDA Characteristics section. and SCL pin.
Typical perForMance characTerisTics Input–Output High to Low ICC vs Temperature Propagation Delay vs Temperature IPULLUPAC vs Temperature
5.3 100 12 5.2 V V CC = 2.7V CC = 5.5V VCC = 5V 5.1 10 80 5.0 VCC = 3.3V 8 4.9 60 (mA) (mA) 4.8 (ns) 6 I CC 4.7 t PHL 40 VCC = 2.7V VCC = 5.5V I PULLUPAC VCC = 3V 4.6 4 4.5 20 2 4.4 CIN = COUT = 100pF VCC = 2.7V RPULLUPIN = RPULLUPOUT = 10k 4.3 0 0 –50 –25 0 25 50 75 100 –50 –25 0 25 50 75 100 –50 –25 0 25 50 75 100 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 4300a3 G01 4300a3 G02 4300a3 G03
Connection Circuitry VOUT – VIN ISD vs Temperature
300 35 TA = 25°C VIN = 0V 250 30 VCC = 5.5V 25 200 (mV) 20 IN 150 (µA) – V VCC = 5V I SD 15 V OUT 100 10 VCC = 3.3V 50 VCC = 2.7V 5 0 0 0 10,000 20,000 30,000 40,000 –50 –25 0 25 50 75 100 RPULLUP (Ω) TEMPERATURE (°C) 4300a3 G04 4300a3 G05 4300a3fa 4 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Package Description Revision History Related Parts Typical Application
