LTC5596 elecTrical characTerisTicsThe l denotes the specifications which apply over the full operatingtemperature range, otherwise specifications are at TC = 25°C. VCC = 3.3V, EN = 3.3V. CW, 50Ω source at RFIN, fRF = 2140MHz, Testcircuit is shown in Figure 1. (Note 2).I-GRADE (NOTE 3)H-GRADE (NOTE 4)PARAMETERCONDITIONSMINTYPMAXMINTYPMAXUNITS Logarithmic Slope Over Operating fRF = 50MHz l 27.6 to 28.6 27.6 to 28.6 mV/dB Temperature Range (Note 7) fRF = 100MHz l 28.2 to 29.4 28.2 to 29.4 mV/dB fRF = 500MHz l 27.4 to 28.9 27.4 to 28.9 mV/dB fRF = 2.14GHz l 28.0 to 29.5 27.5 28.0 to 29.5 31.0 mV/dB fRF = 5.8GHz l 28.0 to 29.4 28.0 to 29.4 mV/dB fRF = 7.6GHz l 28.1 to 29.5 28.1 to 29.5 mV/dB fRF = 10GHz l 28.1 to 29.5 28.1 to 29.5 mV/dB fRF = 12GHz l 28.2 to 29.5 28.2 to 29.5 mV/dB fRF = 15GHz l 28.3 to 29.4 28.3 to 29.4 mV/dB fRF = 18GHz l 28.2 to 29.6 28.2 to 29.6 mV/dB fRF = 24GHz l 28.3 to 29.5 28.3 to 29.5 mV/dB fRF = 26GHz l 28.4 to 29.6 28.4 to 29.6 mV/dB fRF = 28GHz l 28.4 to 29.6 28.3 to 29.5 mV/dB fRF = 30GHz l 28.3 to 29.5 28.3 to 29.5 mV/dB fRF = 35GHz l 28.4 to 29.3 28.4 to 29.3 mV/dB fRF = 38GHz l 28.6 to 29.4 28.6 to 29.4 mV/dB fRF = 40GHz l 28.8 to 29.7 28.8 to 29.7 mV/dB fRF = 43.5GHz l 29.2 to 29.7 29.1 to 29.7 mV/dB Logarithmic Intercept, TC = 25°C (Note 8) fRF = 50MHz –33.1 –33.1 dBm fRF = 100MHz –36.2 –36.2 dBm fRF = 500MHz –39.9 –39.9 dBm fRF = 2.14GHz –39.0 –40.5 –39.0 –37.3 dBm fRF = 5.8GHz –38.7 –38.7 dBm fRF = 7.6GHz –37.9 –37.9 dBm fRF = 10GHz –38.0 –38.0 dBm fRF = 12GHz –37.6 –37.6 dBm fRF = 15GHz –36.5 –36.5 dBm fRF = 18GHz –37.4 –37.4 dBm fRF = 24GHz –38.4 –38.4 dBm fRF = 26GHz –36.8 –36.8 dBm fRF = 28GHz –37.1 –37.1 dBm fRF = 30GHz –38.9 –38.9 dBm fRF = 35GHz –36.3 –36.3 dBm fRF = 38GHz –33.2 –33.2 dBm fRF = 40GHz –31.7 –31.7 dBm fRF = 43.5GHz –27.2 –27.2 dBm Logarithmic Intercept Over Operating fRF = 50MHz l –32.6 to –31.5 –32.6 to –31.3 dBm Temperature Range (Note 8) fRF = 100MHz l –36.5 to –35.5 –36.5 to –35.4 dBm fRF = 500MHz l –40.4 to –38.9 –40.4 to –38.6 dBm fRF = 2.14GHz l –39.7 to –37.2 –40.8 –39.7 to –37.0 –36.3 dBm 5596f For more information www.linear.com/LTC5596 5 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Test Circuit Applications Information Package Description Typical Application Related Parts
