Datasheet LTC5596 (Analog Devices) - 10
Description | 100MHz to 40GHz Linear-in-dB RMS Power Detector with 35dB Dynamic Range |
Pages / Page | 22 / 10 — Typical perForMance characTerisTics. VCC = 3.3V, EN = 3.3V, TC = 25°C, CW … |
File Format / Size | PDF / 2.4 Mb |
Typical perForMance characTerisTics. VCC = 3.3V, EN = 3.3V, TC = 25°C, CW input, 50Ω
LTC5596
Typical perForMance characTerisTics VCC = 3.3V, EN = 3.3V, TC = 25°C, CW input, 50Ω source at fRF = 2140MHz, unless otherwise noted. Linearity Error Temperature Linearity Error Temperature Linearity Error Temperature Variation from 25°C at 50MHz Variation from 25°C at 100MHz Variation from 25°C at 500MHz
3.0 3.0 3.0 125°C 125°C 2.5 125°C 105°C 2.5 105°C 2.5 105°C 2.0 85°C 2.0 85°C 2.0 85°C 1.5 25°C 1.5 25°C 1.5 25°C –40°C –40°C –40°C 1.0 –55°C 1.0 –55°C 1.0 –55°C T ERROR (dB) 0.5 T ERROR (dB) 0.5 T ERROR (dB) 0.5 0 0 0 -0.5 –0.5 –0.5 TURE DRIF -1.0 TURE DRIF –1.0 TURE DRIF –1.0 -1.5 –1.5 –1.5 -2.0 TEMPERA –2.0 TEMPERA –2.0 TEMPERA -2.5 –2.5 –2.5 -3.0 –3.0 –3.0 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 INPUT POWER (dBm) INPUT POWER (dBm) INPUT POWER (dBm) 5596 G19 5596 G20 5596_G21
Linearity Error Temperature Linearity Error Temperature Linearity Error Temperature Variation from 25°C at 2.14GHz Variation from 25°C at 5.8GHz Variation from 25°C at 7.6GHz
3.0 3.0 3.0 125°C 2.5 125°C 125°C 105°C 2.5 105°C 2.5 105°C 2.0 85°C 2.0 85°C 2.0 85°C 1.5 25°C 1.5 25°C 1.5 25°C –40°C –40°C –40°C 1.0 –55°C 1.0 –55°C 1.0 –55°C T ERROR (dB) 0.5 T ERROR (dB) 0.5 T ERROR (dB) 0.5 0 0 0 –0.5 –0.5 –0.5 TURE DRIF –1.0 TURE DRIF –1.0 TURE DRIF –1.0 –1.5 –1.5 –1.5 –2.0 TEMPERA –2.0 TEMPERA –2.0 TEMPERA –2.5 –2.5 –2.5 –3.0 –3.0 –3.0 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 INPUT POWER (dBm) INPUT POWER (dBm) INPUT POWER (dBm) 5596 G22 5596 G23 5596 G24
Linearity Error Temperature Linearity Error Temperature Linearity Error Temperature Variation from 25°C at 10GHz Variation from 25°C at 12GHz Variation from 25°C at 15GHz
3.0 3.0 3.0 125°C 125°C 125°C 2.5 105°C 2.5 105°C 2.5 105°C 2.0 85°C 2.0 85°C 2.0 85°C 1.5 25°C 1.5 25°C 1.5 25°C –40°C –40°C –40°C 1.0 –55°C 1.0 –55°C 1.0 –55°C T ERROR (dB) 0.5 T ERROR (dB) 0.5 T ERROR (dB) 0.5 0 0 0 –0.5 –0.5 –0.5 TURE DRIF –1.0 TURE DRIF –1.0 TURE DRIF –1.0 –1.5 –1.5 –1.5 –2.0 TEMPERA –2.0 TEMPERA –2.0 TEMPERA –2.5 –2.5 –2.5 –3.0 –3.0 –3.0 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10 INPUT POWER (dBm) INPUT POWER (dBm) INPUT POWER (dBm) 5596 G25 5596_G26 5596 G27 5596f 10 For more information www.linear.com/LTC5596 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Test Circuit Applications Information Package Description Typical Application Related Parts
