LTC5596 absoluTe MaxiMuM raTingspin conFiguraTion(Note 1) Supply Voltage (VCC) ...3.8V TOP VIEW RFIN Input Signal Power - Average ...15dBm VCC 1 8 EN RFIN Input Signal Power - Peak (Note 2) ..20dBm OUT 2 7 GND 9 DC Voltage at RFIN ... –0.3V to 1V FLTR 3 6 RFIN DC Voltage at FLTR ... –0.3V to 0.4V GND 4 5 GND DC Voltage at EN ... –0.3V to 3.8V TJMAX .. 150°C DC PACKAGE Case Operating Temperature Range (TC): 8-LEAD (2mm × 2mm) PLASTIC DFN T I-Grade (Note 3) ... –40°C to 105°C JMAX = 150°C, θJC = 25°C/W EXPOSED PAD (PIN 9) IS GND, MUST BE SOLDERED TO PCB H-Grade (Note 4) ... –40°C to 125°C Storage Temperature Range .. –65°C to 150°C orDer inForMaTion http://www.linear.com/product/LTC5596#orderinfoLEAD FREE FINISHTAPE AND REELPART MARKING*PACKAGE DESCRIPTIONTEMPERATURE RANGE LTC5596IDC#PBF LTC5596IDC#TRPBF LGNN 8-Lead 2mm × 2mm Plastic DFN –40°C to 105°C LTC5596HDC#PBF LTC5596HDC#TRPBF LGNN 8-Lead 2mm × 2mm Plastic DFN –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. elecTrical characTerisTicsThe l denotes the specifications which apply over the full operatingtemperature range, otherwise specifications are at TC = 25°C. VCC = 3.3V, EN = 3.3V. CW, 50Ω source at RFIN, fRF = 2140MHz, testcircuit is shown in Figure 1. (Note 2).I-GRADE (NOTE 3)H-GRADE (NOTE 4)PARAMETERCONDITIONSMINTYPMAXMINTYPMAXUNITSRF Input Input Frequency Range 0.1 to 40 0.1 to 40 GHz Input Impedance 52||50 52||50 Ω||fF Detector Response (RFIN to OUT) RF Input Power Range, TC = 25°C fRF = 50MHz –33.2 to 6.3 –33.2 to 6.3 dBm ±1dB LOG-Linearity Error (Note 5, 6) fRF = 100MHz –37.1 to 5.8 –37.1 to 5.8 dBm fRF = 500MHz –40.8 to 3.3 –40.8 to 3.3 dBm fRF = 2.14GHz –39.1 to 4.2 –39.1 to 4.2 dBm fRF = 5.8GHz –39.7 to 3.7 –39.7 to 3.7 dBm fRF = 7.6GHz –38.9 to 4.3 –38.9 to 4.3 dBm fRF = 10GHz –39.0 to 4.2 –39.0 to 4.2 dBm fRF = 12GHz –38.5 to 4.5 –38.5 to 4.5 dBm fRF = 15GHz –37.5 to 5.5 –37.5 to 5.5 dBm fRF = 18GHz –38.4 to 4.6 –38.4 to 4.6 dBm fRF = 24GHz –39.3 to 0.2 –39.3 to 0.2 dBm 5596f 2 For more information www.linear.com/LTC5596 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Test Circuit Applications Information Package Description Typical Application Related Parts
