Datasheet LTC5596 (Analog Devices) - 3
Description100MHz to 40GHz Linear-in-dB RMS Power Detector with 35dB Dynamic Range
Pages / Page22 / 3 — elecTrical characTerisTics. The. denotes the specifications which apply …
elecTrical characTerisTics. The. denotes the specifications which apply over the full operating
elecTrical characTerisTics The denotes the specifications which apply over the full operating
LTC5596
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TC = 25°C. VCC = 3.3V, EN = 3.3V. CW, 50Ω source at RFIN, fRF = 2140MHz, test circuit is shown in Figure 1. (Note 2). I-GRADE (NOTE 3) H-GRADE (NOTE 4) PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
fRF = 26GHz –37.8 to 5.0 –37.8 to 5.0 dBm fRF = 28GHz –40.1 to -0.6 –40.1 to -0.6 dBm fRF = 30GHz –39.8 to 3.1 –39.8 to 3.1 dBm fRF = 35GHz –37.3 to 3.1 –37.3 to 3.1 dBm fRF = 38GHz –34.2 to 3.6 –34.2 to 3.6 dBm fRF = 40GHz –32.6 to 2.9 –32.6 to 2.9 dBm fRF = 43.5GHz –28.2 to 4.6 –28.2 to 4.6 dBm RF Input Power Range Over Operating fRF = 50MHz l –33.2 to 4.6 –28.4 to 3.0 dBm Temperature Range fRF = 100MHz l –37.1 to 5.0 –37.1 to 3.0 dBm ±1dB LOG-Linearity Error (Note 5, 6) fRF = 500MHz l –37.4 to –1.2 –35.9 to –1.2 dBm fRF = 2.14GHz l –39.1 to –0.2 –35.2 to –0.2 dBm fRF = 5.8GHz l –39.6 to –0.7 –35.3 to –0.7 dBm fRF = 7.6GHz l –38.7 to –0.2 –34.7 to –0.2 dBm fRF = 10GHz l –38.8 to –0.5 –34.5 to –0.5 dBm fRF = 12GHz l –36.0 to 0.3 –34.1 to 0.3 dBm fRF = 15GHz l –37.3 to 1.4 –33.5 to 1.4 dBm fRF = 18GHz l –38.2 to –0.1 –35.2 to –0.1 dBm fRF = 24GHz l –39.3 to –1.2 –36.0 to –1.2 dBm fRF = 26GHz l –37.3 to –0.1 –34.8 to –0.1 dBm fRF = 28GHz l –40.0 to –2.5 –36.4 to –2.5 dBm fRF = 30GHz l –39.8 to –2.1 –35.3 to –2.1 dBm ±1.5dB LOG-Linearity Error fRF = 35GHz l –37.7 to 1.3 –32.3 to –1.5 dBm ±1.5dB LOG-Linearity Error fRF = 38GHz l –34.4 to 2.3 –29.2 to –0.2 dBm ±1.5dB LOG-Linearity Error fRF = 40GHz l –33.1 to 1.7 –27.1 to –0.9 dBm ±1.5dB LOG-Linearity Error fRF = 43.5GHz l –28.3 to 3.1 –22.1 to 0.3 dBm Linear Dynamic Range, TC = 25°C fRF = 50MHz 39.5 39.5 dB (Note 6) fRF = 100MHz 42.9 42.9 dB fRF = 500MHz 44.1 44.1 dB fRF = 2.14GHz 43.3 43.3 dB fRF = 5.8GHz 43.3 43.3 dB fRF = 7.6GHz 43.2 43.2 dB fRF = 10GHz 43.1 43.1 dB fRF = 12GHz 43.1 43.1 dB fRF = 15GHz 43.0 43.0 dB fRF = 18GHz 43.0 43.0 dB fRF = 24GHz 39.5 39.5 dB fRF = 26GHz 42.8 42.8 dB fRF = 28GHz 39.5 39.5 dB fRF = 30GHz 43.0 43.0 dB 5596f For more information www.linear.com/LTC5596 3 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Test Circuit Applications Information Package Description Typical Application Related Parts
