Datasheet LTC5596 (Analog Devices) - 4
Description | 100MHz to 40GHz Linear-in-dB RMS Power Detector with 35dB Dynamic Range |
Pages / Page | 22 / 4 — elecTrical characTerisTics. The. denotes the specifications which apply … |
File Format / Size | PDF / 2.4 Mb |
elecTrical characTerisTics. The. denotes the specifications which apply over the full operating
LTC5596
elecTrical characTerisTics The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TC = 25°C. VCC = 3.3V, EN = 3.3V. CW, 50Ω source at RFIN, fRF = 2140MHz, test circuit is shown in Figure 1. (Note 2). I-GRADE (NOTE 3) H-GRADE (NOTE 4) PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
fRF = 35GHz 40.4 40.4 dB fRF = 38GHz 37.7 37.7 dB fRF = 40GHz 35.6 35.6 dB fRF = 43.5GHz 32.8 32.8 dB Linear Dynamic Range Over Operating fRF = 50MHz l 37.8 31.4 dB Temperature Range (Note 6) fRF = 100MHz l 42.1 40.1 dB fRF = 500MHz l 36.2 34.7 dB fRF = 2.14GHz l 38.9 35.1 dB fRF = 5.8GHz l 38.8 34.6 dB fRF = 7.6GHz l 38.5 34.5 dB fRF = 10GHz l 38.3 34.0 dB fRF = 12GHz l 36.3 34.4 dB fRF = 15GHz l 38.7 35.0 dB fRF = 18GHz l 38.1 35.1 dB fRF = 24GHz l 38.1 34.8 dB fRF = 26GHz l 37.2 34.8 dB fRF = 28GHz l 37.6 33.9 dB fRF = 30GHz l 37.7 33.2 dB ±1.5 dB LOG-Linearity Error fRF = 35GHz l 39.0 30.7 dB ±1.5 dB LOG-Linearity Error fRF = 38GHz l 36.7 29.0 dB ±1.5 dB LOG-Linearity Error fRF = 40GHz l 34,7 26.2 dB ±1.5 dB LOG-Linearity Error fRF = 43.5GHz l 31.4 22.4 dB Logarithmic Slope, TC = 25°C (Note 7) fRF = 50MHz 28.2 27.2 mV/dB fRF = 100MHz 28.9 28.9 mV/dB fRF = 500MHz 28.2 28.2 mV/dB fRF = 2.14GHz 29.3 28.0 29.3 30.5 mV/dB fRF = 5.8GHz 28.7 28.7 mV/dB fRF = 7.6GHz 28.8 28.8 mV/dB fRF = 10GHz 28.8 28.8 mV/dB fRF = 12GHz 28.9 28.9 mV/dB fRF = 15GHz 29.0 29.0 mV/dB fRF = 18GHz 28.9 28.9 mV/dB fRF = 24GHz 28.9 28.9 mV/dB fRF = 26GHz 29.1 29.1 mV/dB fRF = 28GHz 29.1 29.1 mV/dB fRF = 30GHz 28.9 28.9 mV/dB fRF = 35GHz 29.0 29.0 mV/dB fRF = 38GHz 29.2 29.2 mV/dB fRF = 40GHz 29.5 29.5 mV/dB fRF = 43.5GHz 29.7 29.7 mV/dB 5596f 4 For more information www.linear.com/LTC5596 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Test Circuit Applications Information Package Description Typical Application Related Parts
