Datasheet E522.80, E522.81, E522.82, E522.83 (Elmos) - 2
ManufacturerElmos
DescriptionTriple 150mA Linear LED Controller
Pages / Page25 / 2 — E522.8x. Note:
E522.8x. Note:
E522.8x Note:
Triple 150mA Linear LED Controller E522.80/81/82/83 Production Data - May 5, 2017 Version ‘OPEN’ Diagnostic Package & Current E522.80 Open Diagnostic at VVS > 7.5V SOIC16N-EP ILED = 48mA...151mA E522.81 Open Diagnostic at VVS > 9.0V SOIC16N-EP ILED = 48mA...151mA E522.82 Open Diagnostic at VVS > 10.0V SOIC16N-EP ILED = 48mA...151mA E522.83 Open Diagnostic at VVS > 15.0V SOIC16N-EP ILED = 48mA...151mA Functional Diagram Switched Supply VS RUNx ENA RUNy Supply HV DIAG RUNz E522.8x Reference Open RUN Drain I/O OVT with Pullup 3x Current LEDxA ENA Dimm Open / Source OFF and Short Thermal Management ENA Derating Detection up to LEDxB Resistor @ LEDx 150mA - High VS per OFF - High Temp Channel - Ext. Derating Current IR 1 Reference Disable / for LEDx IR 2 Resistor to BCM / Driver for Error Detection Controller IR 3 External R SLM From Controller / to GND Single Lamp Mode Optional Current Failure Feedback Reference Circuitry for LEDx E522.80/81/82/83 GND Pin Configuration Top View exposed die pad (bottom side) NC 1 16 NC RUN 2 15 LED1B VS 3 14 LED1A GND 4 13 LED2B ENA 5 12 LED2A IR1 6
E522.8x
11 LED3B IR2 7 10 LED3A IR3 8 9 SLM
Note:
Not to scale Elmos Semiconductor AG reserves the right to change the detail specifications as may be required to permit improvements in the design of its products. Elmos Semiconductor AG Data Sheet QM-No.: 25DS0132E.03 2/25
