Datasheet ADXL354, ADXL355 (Analog Devices) - 9
DescriptionLow Noise, Low Drift, Low Power 3-Axis Accelerometer with digital output
Pages / Page42 / 9 — Data Sheet. ADXL354/ADXL355. PIN CONFIGURATIONS AND FUNCTION …
RevisionA
Data Sheet. ADXL354/ADXL355. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. RANGE 1. 11 V. SUPPLY. ST1 2. ADXL354. 10 V1P8ANA. TOP VIEW
Data Sheet ADXL354/ADXL355 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS RANGE 1 11 V SUPPLY ST1 2 ADXL354 10 V1P8ANA TOP VIEW
link to page 42
Data Sheet ADXL354/ADXL355 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS T T T OU OU OU Z Y X 14 13 12 RANGE 1 11 V Y SUPPLY ST1 2 ADXL354 10 V1P8ANA TOP VIEW ST2 3 (Not to Scale) 9 VSS X TEMP 4 8 V1P8DIG Z 5 6 7 O O Y B
007
DDI SSI V V ST
205- 14 Figure 5. ADXL354 Pin Configuration
Table 7. ADXL354 Pi n Function Descriptions Pin No. Mnemonic Description
1 RANGE Range Selection Pin. Set this pin to ground to select the ±2 g range, or set this pin to VDDIO to select the ±4 g or ±8 g range. This pin is model dependent (see the Ordering Guide section). 2 ST1 Self Test Pin 1. This pin enables self test mode. 3 ST2 Self Test Pin 2. This pin activates the electromechanical self test actuation. 4 TEMP Temperature Sensor Output. 5 VDDIO Digital Interface Supply Voltage. 6 VSSIO Digital Ground. 7 STBY Standby or Measurement Mode Selection Pin. Set this pin to ground to enter standby mode, or set this pin to VDDIO to enter measurement mode. 8 V1P8DIG Digital Supply. This pin requires a decoupling capacitor. If VSUPPLY connects to VSS, supply the voltage to this pin externally. 9 VSS Analog Ground. 10 V1P8ANA Analog Supply. This pin requires a decoupling capacitor. If VSUPPLY connects to VSS, supply the voltage to this pin externally. 11 VSUPPLY Supply Voltage. When VSUPPLY equals 2.25 V to 3.6 V, VSUPPLY enables the internal LDOs to generate V1P8DIG and V1P8ANA. For VSUPPLY = VSS, V1P8DIG and V1P8ANA are externally supplied. 12 XOUT X-Axis Output. 13 YOUT Y-Axis Output. 14 ZOUT Z-Axis Output. Rev. 0 | Page 9 of 42 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ANALOG OUTPUT FOR THE ADXL354 DIGITAL OUTPUT FOR THE ADXL355 SPI DIGITAL INTERFACE CHARACTERISTICS FOR THE ADXL355 I2C DIGITAL INTERFACE CHARACTERISTICS FOR THE ADXL355 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS ROOT ALLAN VARIANCE (RAV) ADXL355 CHARACTERISTICS THEORY OF OPERATION ANALOG OUTPUT DIGITAL OUTPUT AXES OF ACCELERATION SENSITIVITY POWER SEQUENCING POWER SUPPLY DESCRIPTION VSUPPLY V1P8ANA V1P8DIG VDDIO OVERRANGE PROTECTION SELF TEST FILTER SERIAL COMMUNICATIONS SPI PROTOCOL I2C PROTOCOL READING ACCELERATION OR TEMPERATURE DATA FROM THE INTERFACE FIFO INTERRUPTS DATA_RDY DRDY PIN FIFO_FULL FIFO_OVR ACTIVITY NVM_BUSY EXTERNAL SYNCHRONIZATION AND INTERPOLATION EXT_SYNC = 00—No External Sync or Interpolation EXT_SYNC = 10—External Sync with Interpolation EXT_SYNC = 01—External Sync and External Clock ADXL355 REGISTER MAP REGISTER DEFINITIONS ANALOG DEVICES ID REGISTER Address: 0x00, Reset: 0xAD, Name: DEVID_AD ANALOG DEVICES MEMS ID REGISTER Address: 0x01, Reset: 0x1D, Name: DEVID_MST DEVICE ID REGISTER Address: 0x02, Reset: 0xED, Name: PARTID PRODUCT REVISION ID REGISTER Address: 0x03, Reset: 0x00, Name: REVID STATUS REGISTER Address: 0x04, Reset: 0x00, Name: STATUS FIFO ENTRIES REGISTER Address: 0x05, Reset: 0x00, Name: FIFO_ENTRIES TEMPERATURE DATA REGISTERS Address: 0x06, Reset: 0x00, Name: TEMP2 Address: 0x07, Reset: 0x00, Name: TEMP1 X-AXIS DATA REGISTERS Address: 0x08, Reset: 0x00, Name: XDATA3 Address: 0x09, Reset: 0x00, Name: XDATA2 Address: 0x0A, Reset: 0x00, Name: XDATA1 Y-AXIS DATA REGISTERS Address: 0x0B, Reset: 0x00, Name: YDATA3 Address: 0x0C, Reset: 0x00, Name: YDATA2 Address: 0x0D, Reset: 0x00, Name: YDATA1 Z-AXIS DATA REGISTERS Address: 0x0E, Reset: 0x00, Name: ZDATA3 Address: 0x0F, Reset: 0x00, Name: ZDATA2 Address: 0x10, Reset: 0x00, Name: ZDATA1 FIFO ACCESS REGISTER Address: 0x11, Reset: 0x00, Name: FIFO_DATA X-AXIS OFFSET TRIM REGISTERS Address: 0x1E, Reset: 0x00, Name: OFFSET_X_H Address: 0x1F, Reset: 0x00, Name: OFFSET_X_L Y-AXIS OFFSET TRIM REGISTERS Address: 0x20, Reset: 0x00, Name: OFFSET_Y_H Address: 0x21, Reset: 0x00, Name: OFFSET_Y_L Z-AXIS OFFSET TRIM REGISTERS Address: 0x22, Reset: 0x00, Name: OFFSET_Z_H Address: 0x23, Reset: 0x00, Name: OFFSET_Z_L ACTIVITY ENABLE REGISTER Address: 0x24, Reset: 0x00, Name: ACT_EN ACTIVITY THRESHOLD REGISTERS Address: 0x25, Reset: 0x00, Name: ACT_THRESH_H Address: 0x26, Reset: 0x00, Name: ACT_THRESH_L ACTIVITY COUNT REGISTER Address: 0x27, Reset: 0x01, Name: ACT_COUNT FILTER SETTINGS REGISTER Address: 0x28, Reset: 0x00, Name: Filter FIFO SAMPLES REGISTER Address: 0x29, Reset: 0x60, Name: FIFO_SAMPLES INTERRUPT PIN (INTx) FUNCTION MAP REGISTER Address: 0x2A, Reset: 0x00, Name: INT_MAP DATA SYNCHRONIZATION Address: 0x2B, Reset: 0x00, Name: Sync I2C SPEED, INTERRUPT POLARITY, AND RANGE REGISTER Address: 0x2C, Reset: 0x81, Name: Range POWER CONTROL REGISTER Address: 0x2D, Reset: 0x01, Name: POWER_CTL SELF TEST REGISTER Address: 0x2E, Reset: 0x00, Name: SELF_TEST RESET REGISTER Address: 0x2F, Reset: 0x00, Name: Reset RECOMMENDED SOLDERING PROFILE PCB FOOTPRINT PATTERN PACKAGING AND ORDERING INFORMATION OUTLINE DIMENSIONS BRANDING INFORMATION ORDERING GUIDE
