Datasheet ADXL377 (Analog Devices) - 7
DescriptionSmall, Low Power, 3-Axis ±200 g Accelerometer
Pages / Page13 / 7 — ADXL377. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 1.525. 1.520. ) …
File Format / SizePDF / 317 Kb
ADXL377. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 1.525. 1.520. ) %. 1.515. ) V (. TION. 1.510. 1.505. OLTA. T V 1.500. T OF P N. TP 1.495
ADXL377 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 1.525 1.520 ) % 1.515 ) V ( TION 1.510 1.505 OLTA T V 1.500 T OF P N TP 1.495
N > 250 for al typical performance figures, unless otherwise noted. N is the number of parts tested and used to produce the histograms.
35 1.525 1.520 30 ) % 1.515 ( 25 ) V ( TION 1.510 LA GE U 20 1.505 OP OLTA 15 T V 1.500 U T OF P N TP 1.495 E C 10 OU R E 1.490 P 5 1.485 0 1.480 –60 –40 –20 0 20 40 60 80 100
006
4800 4825 4850 4875 4900 4925 4950 4975 5000 5025 5050 5075 5100 5125 5150 5175 5200
003
1. 1. 1. 1. 1. 1. 1. 1. 1. 1. 1. 1. 1. 1. 1. 1. 1. TEMPERATURE (°C)
10765-
OUTPUT VOLTAGE (V)
10765- Figure 3. X-Axis Zero g Output Voltage at 25°C, VS = 3 V Figure 6. X-Axis Zero g Offset vs. Temperature, VS = 3 V (14 Parts Soldered to PCB)
30 1.525 1.520 25 ) % 1.515 ( ) V 20 TION ( 1.510 LA GE U 1.505 OP 15 OLTA T V 1.500 U T OF P N 10 TP E 1.495 C OU R E 1.490 P 5 1.485 0 1.480 –60 –40 –20 0 20 40 60 80 100
007
004
10765-
OUTPUT VOLTAGE (V)
10765- Figure 4. Y-Axis Zero g Output Voltage at 25°C, VS = 3 V Figure 7. Y-Axis Zero g Offset vs. Temperature, VS = 3 V (14 Parts Soldered to PCB)
90 1.525 80 1.520 ) % 70 1.515 ( ) V 60 TION ( 1.510 LA GE U 50 1.505 OP OLTA 40 T V 1.500 U T OF P N 30 TP E 1.495 C OU R E 20 1.490 P 10 1.485 0 1.480 –60 –40 –20 0 20 40 60 80 100
008
005
10765-
OUTPUT VOLTAGE (V)
10765- Figure 5. Z-Axis One g Output Voltage at 25°C, VS = 3 V Figure 8. Z-Axis Zero g Offset vs. Temperature, VS = 3 V (14 Parts Soldered to PCB) Rev. 0 | Page 6 of 12 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Mechanical Sensor Performance Applications Information Power Supply Decoupling Setting the Bandwidth Using CX, CY, and CZ Self-Test Selecting Filter Characteristics: Noise/Bandwidth Trade-Off Axes of Acceleration Sensitivity Layout and Design Recommendations Outline Dimensions Ordering Guide
