Datasheet ADIS16209 (Analog Devices) - 2
DescriptionHigh Accuracy, Dual-Axis Digital Inclinometer and Accelerometer
Pages / Page22 / 2 — ADIS16209* PRODUCT PAGE QUICK LINKS Last Content Update: 06/09/2017. …
RevisionH
File Format / SizePDF / 523 Kb
ADIS16209* PRODUCT PAGE QUICK LINKS Last Content Update: 06/09/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADIS16209* PRODUCT PAGE QUICK LINKS Last Content Update: 06/09/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADIS16209 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADIS16209 Daughter Board • Symbols and Footprints • EVAL-ADIS Evaluation System • EVAL-ADIS2 Evaluation System
DISCUSSIONS
View all ADIS16209 EngineerZone Discussions.
DOCUMENTATION Data Sheet SAMPLE AND BUY
• ADIS16209: High Accuracy, Dual-Axis Digital Inclinometer Visit the product page to see pricing options. and Accelerometer Data Sheet • ADIS16209: Anomaly Data Sheet
TECHNICAL SUPPORT User Guides
Submit a technical question or find your regional support • ADIS16209 Evaluation on the EVAL-ADIS system number.
SOFTWARE AND SYSTEMS REQUIREMENTS DOCUMENT FEEDBACK
• USB Driver File for EVAL-ADISx Platforms (v2.2.95.68, Submit feedback for this data sheet. 3/9/2016)
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS RECOMMENDED PAD GEOMETRY TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC OPERATION OUTPUT DATA REGISTERS Accelerometers Horizontal Incline Angle Vertical Incline Angle Internal Temperature Power Supply Auxiliary ADC OPERATION CONTROL REGISTERS Internal Sample Rate Power Management Digital Filtering Digital I/O Lines Data-Ready I/O Indicator Self-Test General-Purpose I/O Auxiliary DAC Global Commands CALIBRATION REGISTERS ALARM REGISTERS Status APPLICATIONS INFORMATION POWER SUPPLY CONSIDERATIONS Power-On-Reset Function Transient Current from VDD Ramp Rate Filter Settling ASSEMBLY INTERFACE BOARD OUTLINE DIMENSIONS ORDERING GUIDE
