Datasheet ADIS16006 (Analog Devices) - 4
DescriptionDual-Axis ±5 g Accelerometer with SPI Interface
Pages / Page17 / 4 — Data Sheet. ADIS16006. SPECIFICATIONS. Table 1. Parameter. Conditions. …
RevisionC
File Format / SizePDF / 290 Kb
Data Sheet. ADIS16006. SPECIFICATIONS. Table 1. Parameter. Conditions. Min. Typ. Max. Unit
Data Sheet ADIS16006 SPECIFICATIONS Table 1 Parameter Conditions Min Typ Max Unit
link to page 5 link to page 5 link to page 5 link to page 5 link to page 5
TA = −40°C to +125°C, VCC = 5 V, CX = CY = 0 µF, acceleration = 0 g, unless otherwise noted. Al minimum and maximum specifications are guaranteed. Typical specifications are not guaranteed.
Table 1. Parameter Conditions Min Typ Max Unit
ACCELEROMETER SENSOR INPUT Each axis Measurement Range1 ±5 g Nonlinearity % of full scale ±0.5 ±2.5 % Package Alignment Error ±1.5 Degrees Alignment Error X sensor to Y sensor ±0.1 Degrees Cross-Axis Sensitivity ±1.5 ±3 % ACCELEROMETER SENSITIVITY Each axis Sensitivity at XFILT, YFILT 242 256 272 LSB/g Sensitivity Change due to Temperature2 Delta from 25°C ±0.3 % ZERO g BIAS LEVEL Each axis 0 g Voltage at XFILT, YFILT 1905 2048 2190 LSB 0 g Offset vs. Temperature ±0.1 LSB/°C ACCELEROMETER NOISE PERFORMANCE Noise Density At 25°C 200 µg/√Hz rms ACCELEROMETER FREQUENCY RESPONSE3, 4 CX, CY Range 0 10 µF RFILT Tolerance 24 32 40 kΩ Sensor Bandwidth CX = 0 µF, CY = 0 µF 2.26 kHz Sensor Resonant Frequency 5.5 kHz ACCELEROMETER SELF-TEST Logic Input Low 0.2 × VCC V Logic Input High 0.8 × VCC V ST Input Resistance to COM 30 50 kΩ Output Change at X 5 OUT, YOUT Self-Test 0 to Self-Test 1 102 205 307 LSB TEMPERATURE SENSOR Accuracy VCC = 3 V to 5.25 V ±2 °C Resolution 10 Bits Update Rate 400 µs Temperature Conversion Time 25 µs DIGITAL INPUT Input High Voltage (VINH) VCC = 4.75 V to 5.25 V 2.4 V VCC = 3.0 V to 3.6 V 2.1 V Input Low Voltage (VINL) VCC = 3.0 V to 5.25 V 0.8 V Input Current VIN = 0 V or VCC −10 +1 +10 µA Input Capacitance 10 pF DIGITAL OUTPUT Output High Voltage (VOH) ISOURCE = 200 µA, VCC = 3.0 V to 5.25 V VCC − 0.5 V Output Low Voltage (VOL) ISINK = 200 µA 0.4 V Rev. C | Page 3 of 16 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Circuit and Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Accelerometer Data Format Self-Test Serial Interface Accelerometer Serial Interface Accelerometer Control Register Power-Down ADD0 ZERO ONE DONTC Accelerometer Conversion Details Temperature Sensor Serial Interface Read Operation Write Operation Temperature Sensor Control Register ZERO Output Data Format Temperature Sensor Conversion Details Power Supply Decoupling Setting the Bandwidth Selecting Filter Characteristics: The Noise/Bandwidth Trade-Off Applications Second Level Assembly Outline Dimensions Ordering Guide
