Datasheet ADIS16003 (Analog Devices) - 9
DescriptionDual-Axis ±1.7 g Accelerometer with SPI Interface
Pages / Page17 / 9 — ADIS16003. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 890. 870. N …
File Format / SizePDF / 264 Kb
ADIS16003. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 890. 870. N IO T. A L. 850. L (. IT 830. A T. 810. SEN. EN C. ER P. 790. 770. –40. –20. 100. 125
ADIS16003 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 890 870 N IO T A L 850 L ( IT 830 A T 810 SEN EN C ER P 790 770 –40 –20 100 125
ADIS16003 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 890 40 35 870 N IO T 30 ) A L /g 850 PU SB 25 L ( PO Y F IT 830 O 20 IV E T G SI A T 15 810 SEN EN C 10 ER P 790 5
06 09 0 0 3- 3- 546 546
770
0
0
0
–40 –20 0 20 40 60 80 100 125 1900 1929 1958 1987 2016 2045 2074 2103 2132 2161 2190 TEMPERATURE (°C) OUTPUT (LSB)
Figure 7. Sensitivity vs. Temperature (ADIS16003 Soldered to PCB) Figure 10. X-Axis Zero g Bias at 25°C
2200 40 35 2150 N IO T 30 A ) 2100 L SB PU 25 L ( L PO F VE 2050 20 E O E S L G A IA T 15 B 2000 EN C 10 ER P 1950 5
07 10 0 0 3- 3- 546 546
1900
0
0
0
–40 –20 0 20 40 60 80 100 125 1990 1929 1958 1987 2016 2045 2074 2103 2132 2161 2190 TEMPERATURE (°C) OUTPUT (LSB)
Figure 8. Zero g Bias vs. Temperature Figure 11. Y-Axis Zero g Bias at 25°C
2200 45 40 2150 N IO 35 T A ) 2100 L 30 SB PU (L L PO 25 F 2050 EVE O E 20 S L G A IA T B 2000 15 EN C ER 10 P 1950
08 1
5
0 01 3- 3- 46 546
1900
05
0
0
2.8 3.0 3.2 3.4 3.6 3.8 4.0 4.2 4.4 4.6 4.8 5.0 5.2 5.4 60 70 80 90 100 110 120 130 140 150 VCC (V) X-AXIS NOISE DENSITY (µg / Hz)
Figure 9. Zero g Bias vs. Supply Figure 12. X-Axis Noise Density at 25°C Rev. B | Page 8 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS CIRCUIT AND TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ACCELEROMETER DATA FORMAT SELF-TEST SERIAL INTERFACE ACCELEROMETER SERIAL INTERFACE Accelerometer Control Register Power Down ADD0 ZERO ONE DONTC Accelerometer Conversion Details TEMPERATURE SENSOR SERIAL INTERFACE Read Operation Write Operation Temperature Sensor Control Register ZERO Output Data Format Temperature Sensor Conversion Details POWER SUPPLY DECOUPLING SETTING THE BANDWIDTH SELECTING FILTER CHARACTERISTICS:THE NOISE/BANDWIDTH TRADE-OFF APPLICATIONS INFORMATION DUAL-AXIS TILT SENSOR Converting Acceleration to Tilt SECOND LEVEL ASSEMBLY OUTLINE DIMENSIONS ORDERING GUIDE
