Datasheet ADIS16003 (Analog Devices) - 10
DescriptionDual-Axis ±1.7 g Accelerometer with SPI Interface
Pages / Page17 / 10 — Data Sheet. ADIS16003. 100. 110. 120. 130. 140. 150. 350. 400. 450. 500. …
File Format / SizePDF / 264 Kb
Data Sheet. ADIS16003. 100. 110. 120. 130. 140. 150. 350. 400. 450. 500. 550. 600. 650. 700. 750. 800. 850. Y-AXIS NOISE DENSITY (mg/ Hz). OUTPUT (LSB)
Data Sheet ADIS16003 100 110 120 130 140 150 350 400 450 500 550 600 650 700 750 800 850 Y-AXIS NOISE DENSITY (mg/ Hz) OUTPUT (LSB)
Data Sheet ADIS16003 50 60 50 N 40 N IO IO T T A A L L 40 PU PU 30 PO PO F F O O 30 E E G G A 20 A T T 20 EN EN C C ER ER P 10 P 10
12 15 0 0 3- 3- 546 546
0
0
0
0
60 70 80 90 100 110 120 130 140 150 350 400 450 500 550 600 650 700 750 800 850 Y-AXIS NOISE DENSITY (mg/ Hz) OUTPUT (LSB)
Figure 13. Y-Axis Noise Density at 25°C Figure 16. Self-Test at 25°C, VCC at 5.0 V
35 45 40 30 N N IO IO 35 T T A 25 A L L 30 PU PU PO 20 PO 25 F F O O E E 20 G 15 G A A T T 15 EN EN C 10 C ER ER 10 P P 5
13
5
16 0 0 3- 3- 546 546
0
0
0
0
–4.5 –3.5 –2.5 –1.5 –0.5 0.5 1.5 2.5 3.5 4.5 5.5 180 195 210 225 240 255 270 285 300 315 PERCENT SENSITIVITY (%) OUTPUT (LSB)
Figure 14. Z vs. X Cross-Axis Sensitivity Figure 17. Self-Test at 25°C, VCC at 3.3 V
40 750 35 700 N IO ) T 30 /g A L B 650 LS PU 25 ( L PO E F V O 20 600 LE E T G S A T 15 TE F- 550 EN L C E 10 S ER P 500 5
14 17 0 0 3- 3- 546 546
0
0
450
0
–4.5 –3.5 –2.5 –1.5 –0.5 0.5 1.5 2.5 3.5 4.5 5.5 –40 –20 0 20 40 60 80 100 125 PERCENT SENSITIVITY (%) TEMPERATURE (°C)
Figure 15. Z vs. Y Cross-Axis Sensitivity Figure 18. Self-Test vs. Temperature, VCC at 5.0 V Rev. B | Page 9 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS CIRCUIT AND TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ACCELEROMETER DATA FORMAT SELF-TEST SERIAL INTERFACE ACCELEROMETER SERIAL INTERFACE Accelerometer Control Register Power Down ADD0 ZERO ONE DONTC Accelerometer Conversion Details TEMPERATURE SENSOR SERIAL INTERFACE Read Operation Write Operation Temperature Sensor Control Register ZERO Output Data Format Temperature Sensor Conversion Details POWER SUPPLY DECOUPLING SETTING THE BANDWIDTH SELECTING FILTER CHARACTERISTICS:THE NOISE/BANDWIDTH TRADE-OFF APPLICATIONS INFORMATION DUAL-AXIS TILT SENSOR Converting Acceleration to Tilt SECOND LEVEL ASSEMBLY OUTLINE DIMENSIONS ORDERING GUIDE
