Datasheet ADXL103, ADXL203 (Analog Devices) - 6
DescriptionPrecision ±1.7 g, ±5 g, ±18 g Dual-Axis iMEMS® Accelerometer
Pages / Page16 / 6 — ADXL103/ADXL203. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS ADXL103 …
RevisionF
File Format / SizePDF / 867 Kb
ADXL103/ADXL203. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS ADXL103 A. ND ADXL203. ) 20. TION. OP 15. T OF P. N 10. –0. ZERO g. BIAS (V)
ADXL103/ADXL203 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS ADXL103 A ND ADXL203 ) 20 TION OP 15 T OF P N 10 –0 ZERO g BIAS (V)
VS = 5 V for all graphs, unless otherwise noted.
25 30 25 ) 20 ) % % ( ( 20 TION TION 15 LA LA U U OP OP 15 10 T OF P T OF P N N 10 E E C C R R E 5 E P P 5
010 013
0
03757-
0
03757-
0 0 10 08 06 04 02 02 04 06 08 10 10 08 06 04 02 02 04 06 08 10 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. –0. –0. –0. –0. –0. –0. –0. –0. –0. –0. ZERO g BIAS (V) ZERO g BIAS (V)
Figure 5. X-Axis Zero g Bias Deviation from Ideal at 25°C Figure 8. Y-Axis Zero g Bias Deviation from Ideal at 25°C
30 25 25 ) ) 20 % % ( ( 20 TION TION A L 15 LA U PU OP 15 PO F O 10 T T OF P N 10 EN E C C R E PER P 5 5
011 014
0
03757-
0
03757-
0 80 70 60 0 50 40 30 20 10 10 20 30 40 50 60 70 80 80 70 60 50 40 30 20 10 10 20 30 40 50 60 70 80 0. 0. 0. 0. 0. 0. 0. 0. –0. –0. –0. 0. 0. 0. 0. 0. 0. 0. 0. –0. –0. –0. –0. –0. –0. –0. –0. –0. –0. –0. –0. –0. TEMPERATURE COEFFICIENT (mg /°C) TEMPERATURE COEFFICIENT (mg /°C)
Figure 6. X-Axis Zero g Bias Temperature Coefficient Figure 9. Y-Axis Zero g Bias Temperature Coefficient
40 40 35 35 ) ) % % ( 30 ( 30 TION TION 25 25 LA LA U U OP 20 OP 20 15 T OF P T OF P 15 N N E E C C R 10 R 10 E E P P 5 5
012 015
0
03757-
0
03757-
94 95 96 97 98 99 00 01 02 03 04 05 06 94 95 96 97 98 99 00 01 02 03 04 05 06 0. 0. 0. 0. 0. 0. 1. 1. 1. 1. 1. 1. 1. 0. 0. 0. 0. 0. 0. 1. 1. 1. 1. 1. 1. 1. SENSITIVITY (V/g) SENSITIVITY (V/g)
Figure 7. X-Axis Sensitivity at 25°C Figure 10. Y-Axis Sensitivity at 25°C Rev. E | Page 6 of 16 Document Outline Features Applications General Description Functional Block Diagrams Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics ADXL103 and ADXL203 AD22293 AD22035 and AD22037 All Models Theory of Operation Performance Applications Information Power Supply Decoupling Setting the Bandwidth Using CX and CY Self Test Design Trade-Offs for Selecting Filter Characteristics: The Noise/Bandwidth Trade-Off Using the ADXL103/ADXL203 with Operating Voltages Other than 5 V Using the ADXL203 as a Dual-Axis Tilt Sensor Dual-Axis Tilt Sensor: Converting Acceleration to Tilt Outline Dimensions Ordering Guide Automotive Products
